Question about Mach Speed Eclipse V415 (4 GB) MP3 Player
How to get artwork on my eclipse 2.8V series - Mach Speed Eclipse V415 (4 GB) MP3 Player
Tip
How to add album artwork, lyrics to your iTunes (iPod Touch and iPhone) songs.
This is what the iPod app looks like (sideways - coverflow view) with the correct album artworks in each song.
... isn't that lovely?
To have that, this is what you gotta do:
First, you need to have the correct album artwork of your songs. And how do you know if you got the right album artwork?
Check it out here or you can use this web address:
http://lyrics.wikia.com/Green_Day:Dookie_(1994)
Tip: if you want a larger image, just google it, just like this sample.And another thing, you don't need to save all the artworks on your computer, just copy-paste will do (refer number 6 below).
Just make the artwork available for you to copy from your internet browser.
Now that you have the correct artwork, here's what you need to do next:
Take note that the procedure will be the same for both Mac and Windows.
1. Open iTunes.
2. Select Music.
3. Right-click on the song where you want to add/replace the album artwork.
4. Select "Get Info" to open the song properties.
5. Select the "Artwork" tab, which happens to be the last tab.
6. Add the correct artwork or delete any wrong artwork that you see there and replace it, by clicking "Add..." button and locating the correct artwork from your computer.
Another way of adding/replacing the artwork is to open the correct album artwork from your files or like I've mentioned above, straight from the internet (thru google or wherever), right click on the image and select "Copy". and then go back to song properties on iTunes and paste it by clicking CTRL-V (control, then V) from Windows keyboard or Command-V (command, then V) from Mac keyboard.
7. Finally, click the "Ok" button to save your changes.
Adding or replacing lyrics will take the same steps except that there is no "Add..." button there, only copy-paste or type it yourself.
Tip: it'll be easier if you do all of these stuffs simultaneously.
8. After you've fixed the song properties, sync your iPhone / iPod Touch to iTunes.
And you're all done! Congratulations!
on Feb 09, 2010 | Apple iPod touch
Cant delete incorrect album artwork from itunes albums; on my mac. Trying to drag new artwork onto the album doesn't work, nor can I remove by dragging incorrect artwork to trash. The artwork appears to be...
The easiest way to address this issue is to edit multiple album tracks at once. To do this, select the first track of the album artwork you would like to change. Hold the shift key and click the final track. Next, right click the songs you have selected (which will now be in blue). Select the menu item "Get Info". From the "Multiple Item Information" pop up, remove the current artwork in the artwork box (if needed) and click the check box next to artwork. Select ok.
This will remove the artwork for all items which you have selected.
Apr 05, 2011 | Apple iTunes
My Ipod keeps displaying the wrong album artwork when i'm listening to music
That's because it's really wrong. If you have the correct album artwork saved on your computer, this is the way to fix it.
1. Open iTunes.
2. Select Music.
3. Right-click on the song with incorrect album artwork.
6. Delete the wrong artwork that you see there and replace it by clicking "Add..." button and locating the correct artwork from your computer.
Another way of replacing it is to open the correct album artwork (from your computer), right click on the image and select "Copy". and then go back to song properties on iTunes and paste it by clicking CTRL-V (control, then V) from Windows keyboard or Command-V (command, then V) from Mac keyboard.
BTW, you can also modify the song title, and the lyrics from the song properties.
I hope that solves your problem.
Click here to see more of this tip and also to see screenshots plus how to add lyrics.
How to get album art?
  1. Click on "Advanced" which is found at the top of the screen. Select "Get Album Artwork" from the drop down menu. It will ask you "Are you sure you want to get album artwork?" Hit "Get Album Artwork". Before you do that, you can select "Don't ask me again" if you don't want this to pop up in the future.
  2. Wait until it is done searching for the artwork. A window will pop up saying that it either found all artwork or they didn't. If they did, then great, your done, plug in your iPod and start jamming. But if they didn't, you can still jam away, but check the song title, album name, artist, and genre to see if you got it typed in correctly. Type in what they are supposed to be and try again.
  3. If they still can't find it, then you can add them manually. Look at the link below to find out how to do it manually.
OR
If Itunes wont find the art work:
  1. Find the artwork for the album on the internet. Try using Wikipedia. Click on the artwork to get a larger image. If you can't find it there, I'm sure you can find it using Google images. Anyway, once you find it drag it to your desktop. Make sure it is on there before you continue.
  2. Next, you need to highlight the songs that are in the album you are getting artwork for. To highlight multiple songs, click on the first song and then while holding the shift key click on the last song. To highlight multiple songs that aren't grouped together, click on all the songs while holding the command key on a Mac and ctrl key on a PC.
  3. Now go to "File" then "Get Info". A window will pop up asking you if you want to edit multiple items. Click "Yes". Another window will pop up labeled "Multiple Item Information". You will notice a box on the right hand side of the window that says "Artwork". Click and drag the artwork that is on your desktop into that box. It should appear there. When it does, select "Ok".
  4. When it is done processing, plug your iPod into the computer, sync it, and take your iPod out to start listening to your improved music.
Sep 30, 2009 | Apple iPod touch
My ipod nano keeps not displaying artwork on the ipod but displays it on itunes?
mine does that too.. sometimes the artwork just isn't compatible with the iPod, and sometimes, it just isn't compatible with the song, because people can lock the songs so that artwork can't be added.
Aug 02, 2009 | Apple iPod nano 3rd Generation
My (black) ipod chromatic nano blacks out multiple album artworks
Try deleting the artwork and adding it back in, it worked for me when it blacked out my artwork.
Mar 30, 2009 | Apple iPod nano MP3 Player
Illustrator to photoshop
Here is everything you will need. I hope you will find this worthy of a FixYa rating.
Import Illustrator CS2-CS3 artwork into Photoshop CS2-CS3
What's covered In Adobe Photoshop, you can import Adobe Illustrator artwork in several different ways, each of which offers a different level of control. When you open or place AI, EPS, or PDF files created by Illustrator, Photoshop rasterizes vector artwork and removes the ability to edit transparency, fonts, layers, and paths. To retain more control over imported Illustrator artwork, Adobe recommends that you drag or paste it into a Photoshop image or export it in Photoshop format.
Drag Illustrator artwork into Photoshop Dragging Illustrator artwork is the quickest way to import it into Photoshop. By default, Photoshop creates a new layer for the dragged artwork and imports the artwork as a Vector Smart Object. (For more information, see "Smart Objects" in the Photoshop Help.) You can import dragged vector artwork as a work path, however, by holding down Control (Windows) or Command (Mac OS) while dragging. To center imported artwork in the Photoshop image, hold down Shift while dragging.
Note: To import dragged type as a work path, you must first convert it to outlines in Illustrator. For more information, see "Modifying letterforms as graphic objects" in Illustrator Help.
Paste Illustrator artwork into Photoshop When you copy Illustrator artwork, you can paste it into Photoshop and retain many Illustrator features. To do so, however, you must properly configure Clipboard preferences in Illustrator.
The Illustrator Clipboard supports a variety of formats including: PICT, PDF, and AICB. Though Illustrator always copies PICT data to the clipboard, you can configure Illustrator so that it also copies PDF or AICB format. These two formats allow you to retain Illustrator features in artwork pasted in Photoshop. PDF retains Illustrator transparency, while AICB format retains Illustrator paths.
You should only select the AICB format by itself if you are going to be pasting paths in to Photoshop. In all other cases, select the PDF format or the PDF format in conjunction with AICB. The PDF format retains transparency and other features in Illustrator such as extended support for spot colors.
To configure Clipboard preferences in Illustrator:
  1. Choose Edit > Preferences > Files & Clipboard (Windows) or Illustrator > Preferences > Files & Clipboard (Mac OS X).
  2. In the Clipboard section, select the desired format.
  3. If you selected AICB, select either Preserve Paths or Preserve Appearance.
  4. Click OK.
Paste options in Photoshop
When you use the Paste command to import copied Illustrator artwork, Photoshop provides the following options in the Paste dialog box:
  • Paste as Smart Object: Pastes the art as a Vector Smart Object that can be scaled, transformed, or moved without degrading the image before it's placed into the Photoshop document. As the art is placed, its file data is embedded in the Photoshop document and the art is rasterized on a separate layer.
  • Paste as Pixels: Pastes the copied artwork in a new layer and rasterizes it at the resolution of the Photoshop image. Use this option when pasting raster objects.
    Note: When you use this option, clipping masks for raster images are not retained as paths. These masks still clip images, however.
  • Paste as Path: Pastes the copied artwork as a work path.
  • Paste as Shape Layer: Pastes the copied artwork in a new vector shape layer. Compound Illustrator shapes retain their attributes and remain editable. Multiple copied paths and clipping masks are pasted as multiple paths that use the unite attribute .
    Note: When you use this option, pasted objects use the foreground color in Photoshop, not the fill color they use in Illustrator. Likewise, transparent objects become opaque.
Export Illustrator files in Photoshop format Exporting Illustrator documents files in Photoshop format gives you the most control over Illustrator artwork in Photoshop. With this method, you can specify resolution and enable anti-aliasing for rasterized artwork. You can also retain the following Illustrator features:
  • Editable text
  • ICC profiles
  • Layers, including nested and hidden layers
  • Masks
  • Transparency
  • Compound shapes
  • Slices and image maps
Note: A compound shape must have either no stroke or a stroke with a round join that uses whole integers for the stroke weight. However, the compound shape can reside on a layer with other objects. In that situation, Photoshop places the other objects on a separate layer in the same layer set.
For more information about exporting Illustrator files in Photoshop format, see "Photoshop export options" in Illustrator Help.
Open Illustrator (AI) files in Photoshop You can open AI files in Photoshop if you save them using the Create PDF Compatible File option.
To save an AI file using the Create PDF Compatible File option:
  1. Choose File > Save As.
  2. Choose Illustrator (*.AI) as the file format, and click Save.
  3. Click Create PDF Compatible File in the Illustrator Options dialog box, and click OK.
Thanks,
Lee
Jun 18, 2008 | Adobe Photoshop 7.0 for PC
How do I put album artwork on my i-pod nano 3rd generation?
you cannot put album artwork on your ipod, it eother comes with the mp3 file or if your importing from a cd the artwork is within and put in the ipod.
Jan 01, 2008 | Apple iPod nano
60 Gb Ipod Album Artwork issue
I don't really know anything about it. But if you're gonna toss it, I won't mind if you tossed it to me. abiolaawonusi@yahoo.co.uk
Nov 01, 2006 | Apple iPod MP3 Player
Mach Speed Eclipse V415 (4 GB) MP3 Player Logo
Top Mach Speed Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
Gyula Lacz
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
