Question about DVD & Blu-Ray Players
Need to reset factory
I pressed a bunch of buttons. I did not know what I was doing. How do I reset the factory default settings?
The Marv
  • 72 Answers
SOURCE: stuck on either PScan or PAL; can i reset the whole darn player?
To reset Cyberhomes DVD players. Take the dvd out close the tray. then press and hold stop for five seconds.
Posted on Aug 05, 2006
SOURCE: unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Posted on Sep 04, 2007
SOURCE: toshiba dvd setting
1. You would press and hold stop on the front of the unit for 5 seconds then let go and press it again normally, you can try this with both the power of the unit on and off.
Posted on Sep 24, 2007
SOURCE: Cannot play any dvds - re "rating"
power on, open disc tray.
On the machine, press and hold the record button and add another finger to hold the Play (x1.3) for 5-10 seconds. The door should stay open. The rating will change to 8.
Posted on Jun 13, 2008
SOURCE: How to reset (manually) factory defaults?
Although not a very visible fix it can be done quickly if you still have your user's manual. Locate your configuring your recorder section of your manual. Get familuar with the system setup - general page. Push the setup button on your remote and navigate yourself through the unclear display using your manual. Then simply toggle between Progressive and Interlace video. Other option using same page in manual and same "blind" procedure just restore your factory setting.
Hopefully fixes your problem or at least points you in the right direction.
Posted on Dec 10, 2008
SOURCE: Command mode change disabled remote
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Posted on Apr 03, 2009
0 characters
1 Points
How to hard reset my philips blue ray
BDP5506, HTS5506, BDP3306, HTS3306, BDP3506, HTS3506, BDP3106, HTS3106
Press the [Home] button on the remote. Then select [Setup]>[Advanced Setup]>[Restore defaults settings]>[Reset Network Setting]>[Yes]
Press the [Home] button on the remote. Then select [Setup]>[Advanced]>[Restore default settings]>[OK]
BDP7320, BDP7520, BDP5320
Press the [Home] button on the remote. The select [Settings]>[Factory Default]>[Network Settings]>[Yes]
Feb 09, 2016 | Philips DVD & Blu-Ray Players
Pioneer dvd recorder dvr 310
Resetting the Recorder to Factory Settings
1. Make sure that the recorder is on
2. Press and hold the STOP button and STANDBY/ON button.
The recorder turns off with all settings reset.
Try this and let me know if it works.
Mar 27, 2008 | Pioneer DVR-3100 DVD DVD Recorder
Factory reset
Use Default Settings If you want to return the initial language setting such as Language, Video, Audio and etc. to the factory default, do the following: 1) Press SETUP button. 2) Press / button to select Misc. 3) Press button to select Use Default Settings, then press ENTER button. 4) Press / button to select "Yes", then press ENTER button. The original setting will be restored. Screen saver : On Do you want to use default setting? Note When you reset the DVD player to the factory default, the DVD player will take 3-5 seconds to reset.
Oct 15, 2014 | Toshiba SDK990 Player
How do you reset a vizio blu ray player to default?
Find System Settings on the Main Menu. Under System Settings there is an option to Reset To Factory Defaults. Under Reset To Factory Defaults you have options to Reset settings to Factory Default or Deactivate accounts.
Sep 02, 2012 | Vizio VBR220 Blu-Ray Player
Rca drc8295n reset parental codes I bought this unit at a yard sale for five bucks... It plays cd, vhs tapes, but when I put a dvd in it wont play and I see a pad lock on the little display. I am assuming...
Page 55 of the user manual shows a way you may be able to 'reset' the player back to factory defaults and/or if a parental lock has been set and the password is unknown/forgotten:
* Press the STOP button on the front of the unit while you press the STOP button on the remote control-keep pressing both buttons for approximately 3 seconds (until the 'padlock' icon disappears from the front panel display). Release both buttons (the player should be unlocked). If that doesn't work, try resetting the DVD/VCR (instructions are listed below).
* Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON button while you press and hold the STOP button-wait at least 3 seconds before you release both of the buttons.
You'll need to set up your menu preferences because this Reset Procedure returns the DVD/VCR's menus to the factory default settings and also erases the disc library.
( sourced from: )
You can always go to the above site and download the free pdf of the owner's manual for this model if necessary (follow the prompts).
Give the suggestions a try before considering downloading the documentation.
Apr 26, 2011 | RCA DRC8295N DVD Recorder/VCR
Says not responding when i press play
Just reset it to factory settings. Sometimes improper keying inputs may make the system control confused. Resetting it to fatory settigs will rectify it. to reset it to factory settings do the following.
• Press the (>>') button (in front panel) for more than 5 seconds with no disc
inside. All settings including the password will revert to the factory
settings. • When the factory default settings are restored, all the user data stored in
the persistent storage will be deleted. OK.
Feb 13, 2011 | Samsung BD-P1500 Blu-Ray Player
I need to manually reset my pioneer dv 490v to factory setting
here is the link to your manual:
to reset:
Resetting the player
Use this procedure to reset all the player’s
settings to the factory default.
1 Switch the player into standby.
2 Using the front panel buttons, hold
down the
(stop) button and press
STANDBY/ON to switch the player back
All the player’s settings are now reset.
Feb 14, 2010 | Pioneer DV-490V-K DVD Player
Is there a way to do a Factory reset
post back with make and model.
Also not heard of that to be honest but better off checking in the manual or calling the manufacturer and asking.
If you can clarify whats wrong exactly or why you want to restore to factory defaults.
The only thing I can think of is if you press the menu button or go into the settings there is normally a reset to factory defaults in there somewhere.
Apr 15, 2009 | DVD & Blu-Ray Players
DVD player
try to reset it to factory settings.
Jan 11, 2008 | Cyberhome CH-DVD 300 DVD Player
Blank Screen
There is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds (some solutions say 20 seconds).
Aug 16, 2007 | Cyberhome CH-DVD 300 DVD Player
DVD & Blu-Ray Players Logo
1,197 people viewed this question
Top DVD & Blu-Ray Players Experts
Are you a DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
