Question about GE PFSF2MIYWW (222 cu ft) Bottom Freezer Commercial French Door Refrigerator
Ice buildup in the freezer - GE PFSF2MIYWW (222 cu ft) Bottom Freezer Commercial French Door Refrigerator
  • 183 Answers
SOURCE: Frost buildup on ice/water dispenser
Your problem is definatly caused by air entering freezer either from the ice shute flap or door not sealing correctly, try putting a bright torch in frezzer and closing door look for light escaping around edge of door, if you can see the light then change door seal, the fault cannot be anything else. Regards Advisor
Posted on Aug 30, 2007
Maytag317
  • 1136 Answers
SOURCE: Ice buildup around freezer door seal.
Hi, Check and see if the gasket is leaking any where. Also check and see if the door to you ice dispenser is closing. Ice/frost only builds up around the door hen there is an air leak.
I hope this helps you. Please let me know if I can assist you further,
Thanks
Vic
Posted on May 23, 2009
jumptrout51
  • 3361 Answers
SOURCE: the lines inside my refrigerator freeze up with ice buildup
Replace the defrost heater and defrost thermostat in the freezer section. They are located behind the freezer panel.
Posted on Jul 14, 2009
aasc
  • 1606 Answers
SOURCE: ge mod.pde18lzpbww.defrost tray ice buildup every
Remove the rear panel inside the freezer . Defrost the drain tray whr=ere the drain hole is until water will flow down it . Hot water sometimes helps . Use a small hose inserted into the drain and blow out any debris . Get a Solid ALUMINUM wire about 9 inches long (14-16 guage) and put into the hole as far as possible without using force (bend the wire if necessary) and make a hook with the other end ahich you should hook onto the defrost heater . This ALUMINUM wire will keep the drain hole cleared of ice due to the transfer of heat from the glass defrost heater . Do not make the hook too tight for fear of breaking the glass covering on the heater .
Posted on Aug 16, 2009
  • 32 Answers
SOURCE: GE side by side freezer not working - ice buildup
check the defrost timmer if it is working you need a defrost heater you can manually turn the defrost timmer to check the heater the timmer turns off the compressor and on the heater 2 or 3 times a day the timmer is a box with a round knob sticking out of it turn the knob tell it clicks look under the front for it or in the back most refrigerators have a wiring diagram on the back or by the compressor
Posted on Oct 20, 2009
Back wall ice buildup, fridge not cooling but freezer is fine other than ice. Back wall of refrigerator squishes with sound of water behind it. Have had it unplugged for 24 hours, ice gone.
Anytime you have ice buildup in back of freezer it indicates that the auto defrost mechanism is not working. Check the defrost timer, heater element, defrost thermostat for proper operation.
Jul 19, 2015 | GE Profile 24.7 cu. ft. Top Freezer...
The freezer works great, but the refrigerator isn't cooling properly as of yesterday
Check the vents coming into the frig from the freezer and with the fan in the freezer blowing feel if there is any air blowing into the frig., if not then check for ice buildup in the freezer. sometimes the ice will block the fan and or vents. Defrost if there is frost and ice buildup.
Mar 09, 2010 | Whirlpool Refrigerators
Ice buildup in freezerator freezer section
If it is not a frost less freezer you'll have to remove perishables to another fridge/freezer; unplug and de-thaw the unit.
Nov 21, 2009 | Gladiator GAFZ21XXMK Bottom Freezer...
Refrigerator side doesn't keep things cold, just cool, despite having it on the coldest setting and the cold vent open between the freezer. The freezer is working fine.
Look on the back wall of the freezer for a ice buildup. If there is ice you have a defrost problem. The defrost timer is in the fresh food section inside the control panel.The defrost heater and defrost thermostat are behind the freezer back panel inside the freezer.
Also check the freezer fan. If there is no ice buildup in the freezer the freezer fan motor could be bad.
Nov 21, 2009 | Jenn-Air JSD2789GES Side by Side...
The lines inside my refrigerator freeze up with ice buildup
Jul 14, 2009 | GE GSH25JFR Side by Side Refrigerator
Ice buildup on the coil and ice buildup on freezer floor
you will have to unclogg it..hot water/hairdryer..flexible tubing to push out the clog. the ice on evap coil bothers me though. do all the coils get frosty white(close the door for 10 minutes then check) I fear they aren't and you have a freon leak.
Jun 13, 2009 | Refrigerators
Thanks
Vic
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Aug 27, 2007 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
GE PFSF2MIYWW (222 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
14 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
