Question about Coralife Power Center DayNight Timer or WaveMaker Timer Life Support
Hi the clock is set for 60 Hertz, What about countrys with 50 Hertz in voltaje?
It runs 50 minutes for an hour
  • Coralife Master
  • 5,245 Answers
50 Hz means the electric generator rotates 50 times per second.
And then electricity oscillates or reverses polarity 50 times per second.
Products rated for 60 Hz will not operate correctly with 50 Hz power.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Feb 16, 2014
Cloc gains time
well without the make and model number I can only answer generally , most clock radios use the power line to sync the time base (60 hertz=60 seconds = 1 minute=60 minutes=1 hour) , but they use a internal time base generator when running on battery back-up (that's not so accurate) , I had one some time back that a customer plugged into a switched outlet (unknown to them) in there room and it did exactly the same thing it gained about seven minutes every day , me id check the outlet its plugged into to see if its on all the time (a quick test 4 this is to remove battery back up ) clock will then flash to be reset if you come back later to see it when the power was shut off
Jul 26, 2016 | Audio Players & Recorders
How to get a 115/60 MZ machine in a 110/50 mZ country
Buy it in the US or Canada online and pay for shipping
Apr 11, 2015 | Kenmore Elite 45986 Front Load Washer
How to convert 50 hz waterpump to 60 hz??
you cant but difference between 50/60 hertz should not stop in running does the rest of machine work ok does it wash spin if so I would be lokking for wires of jammed pump ect
Mar 08, 2014 | Samsung Washing Machines
I recently purchased an Audiovox Clock Radio CR20 from the USA on a visit to that country. I am back in my home country India and started using the clock radio. I find that the clock is not keeping correct...
The reason of your problem is that your local mains frequency is 50 Hz and when you use 230V to 120V converter, this simple device can not convert frequency only the voltage. Your clock is synchronized to the mains frequency which is 50 Hz instead of 60 Hz and the clock goes slowly. It is late (60-50)/60 ---> 10 minutes in every hour.
I am sorry but I think your problem can not be fixed. ( It would be possible to convert the frequency but the cost of this kind of device would be higher than the value of this Audiovox)
Thanks.
gylacz
Aug 10, 2011 | Audiovox Audio Players & Recorders
50 hertz microwave to send in Philippines which frequency is50-60
u.s. is all 60 hz. not sure in the phillipines,the only issue is it will cook slower due to the lower input frequency, it shows no electronic control board in the diagram, sometimes a different freq. can throw electronics off i.e. the clock would run slower and not keep accurate time on 50 hz. as it would on 60hz.
Oct 11, 2009 | Sharp R-510HW Microwave Oven
Clock runaway
You are right on, the clock is using the 50 hertz to keep time expecting it too be 60 hertz.
Dec 27, 2007 | GE RP4842 Clock Radio
Emerson Research Clock modelSmartSet
The problem is most likely the frequency of the A/C power there. In the US our power runs at 60 cycles p/second and the alarm clock uses this to set the time. Sounds like India is running 50 cycles like Europe does. Most likely there is a jumper in the clock because the Ckt board on mine shows a 50/60 hertz setting but with out the board schematics I wouldn't have a clue how to fix it. Sorry not to help more...
Dec 01, 2007 | Emerson Smartset Clock Radio
JCR-160 clock radio Clock running slow
The clock works off the frequency (hertz). In US the electrical wave frequency is 60HZ/sec and in India and many other countries 50HZ/sec. Hence, the clock slows down about 6 seconds or so every minute.
Mar 12, 2007 | Jensen JCR-425 Clock Radio
Coralife Power Center DayNight Timer or WaveMaker Timer  Life Support Logo
47 people viewed this question
Top Coralife Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Coralife Hardware and Accessory Expert? Answer questions, earn points and help others
