Question about Samsung ML-2510 Laser Printer
New Samsung Laser Monorchrome Printer Fuse didn't reset
I re-filled my re-manufactured toner cartridge and installed a new fuse but the paper count did not reset. I dumped out the old ink before I refilled it. The count is at 9355. The print quality is pretty good. Does the total page count effect the cartridge? I did a refill because the print was getting to light for reading barcodes. I never received a red flashing light to replace the cartridge. I also removed the cartridge and re-inserted it took look at the fuse. It wasn't burned.
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 150 Answers
REPLACE THE NEW TONER CARTRIDGE OR REPLACE THE CARTRIDGE CHIP &FUSE
Posted on May 08, 2014
komguy
  • 2306 Answers
SOURCE: Smasung ML2510 Laser print quality poor especially on graphics
Full isn't always the answer, in order to refill a cartridge properly you need to also replace the cleaning blade inside. The blade wears out and doesn't clean the drum properly and also lets toner leak all over. Your best bet is a new OEM cartridge, or put a new cleaning and Dr. blade in yours.
Posted on Jul 29, 2009
xptareq2000
  • 1447 Answers
SOURCE: how to reset samsung scx 4300 printer cartridge
you can not reset this chip change it you must be buy a new one cartridge
Posted on Nov 04, 2009
nakshatraipu
  • 241 Answers
SOURCE: my printer massage display toner exhied
no there is no solution to short pin, it has software solution to reset printer.
We have Zero cost solution for samsung -scx-4300, ml-2240,ML
2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Posted on Nov 14, 2009
nakshatraipu
  • 241 Answers
SOURCE: toner is exhausted!! insert a new toner; this
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Posted on Nov 18, 2009
SOURCE: how can i refill my samsung ml1640 printer cartriage or reset it
send me your e-mail address i can send to you detailed information how to reset toner counters with software
MUSTAFA BULENT KILIMCI
YUNUS COMPUTER CEO
COMPUTER EXPERT
e-mail & msn : address mbkilimci@yunuscomputer.com
Posted on Jan 07, 2010
Why toner empty error in samsung sf 565p
I have an SF-555P and have installed numerous cartridges. The last one was a Samsung brand and it didn't have the little fuse taped on the top. I never knew what this was fur until I had problems. When I first installed the new cartridge the "Toner Low" display remained lit. I shook the cartridge and it persisted but it printed well. Then about 100 pages later I got the "TONER EMPTY" and the printer stopped. After researching the issue I found that the fuse is actually a reset for the printer counter and when the new cartridge was installed without the fuse, it never reset.
You will need a 5X20 Fast acting fuse, no greater than 315 ma. You can buy a 4 pack from Radio Shack for about $3 (P N 2701046). Install it with a piece of electrical tape in the slot on the toner cartridge and make sure the contacts are exposed. The printer will blow the fuse and reset the counter. Don't use a bigger fuse, a slow-blow or anything that won't burn open quickly or you will be buying a new printer.
Mar 18, 2010 | Samsung SF-565P All-In-One Laser Printer
Have you found a solution to the Samsung ml-2510 printer red error light staying problem?
There are a couple of reasons why this happen. A paper jam could have occurred. The cover might be open, try closing the
cover. There might be no paper in the tray, load paper in the tray. The toner cartridge is not installed. The printer has stopped printing due to a major error (you need to contact your manufacture for this).
Nov 11, 2009 | Samsung ML-2510 Laser Printer
Samsung sf-5100 fax toner empty
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Mar 05, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Can't receive fax but can send fax
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Replace black toner
Does the message say Replace, or Reinstall a subtle difference, but it does matter.
If it says Reinstall, the problem is that the printer is not making electrical contact with the three small copper pads on the side of the cartridge. Wipe to remove any toner etc, and when you re-fit the cartridge 'wizzing' it back and forth a couple of times usually works. If it doesn't, look at those contacts - do they look neatly in line - none of thembadly mis-shapen ?
If it says Replace, is the cartridge a new OEM one - if so its faulty
If its a remanufactured one, the reset fuse probably wasn't replaced.
If you refilled it yourself, are you thinking what's a reset fuse ?
The reset fuse is what 'tells' the printer a new cartridges has been fitted, and zeros the count for that cartridge.
Sep 09, 2008 | Samsung CLP-500 Laser Printer
Cru fuser error
I already solved the cru fuser error by replacing the fuse of the toner cartridge.Thanks anyway for this information.
Jun 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Toner end life
it is printing with this blinking or not?
Jan 04, 2008 | Samsung ML-2510 Laser Printer
Toner and Imaging Unit issues
If this IS a CLP-510, first make an information confirmation print.
Press MENU, then press ENTER, and ENTER again.
Look at the counter for the imaging unit, is it a low count confirming that you have indeed replaced it ?
If not you will need to reset the counter.
Check the counters for the toner cartridges, and check the capacity of the cartridge. On a CLP-510 the image counter for the toner is held on the chip on the cartridge (which also identifies the capacity of the cartridge).
There have been some faulty (oiginal Samsung chips), and of course re-manufactured cartridge chips could fail (many re-manufacturers don' test their cartridges before dispatch, they don't have the facility to do so without starting the count on the chip (or 'bowing' the reset fuse on a CLP-500 cartridge). VERY few re-manufacturers can test these cartridges without starting the count.
Sometimes the 'replace xxxxx toner' messages are caused by toner on the three contacts on the side of the cartridge, or their mating contacts inside the printer. Rarely, this can be caused by a faulty circuit board.
Dec 20, 2007 | Samsung CLP-510 Laser Printer
Samsung ML-2510 Laser Printer Logo
89 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
