Question about Waring WMK300 Professional Belgian Waffle Maker
Waring WMK 600 pro
Availability of a wiring diagram?
Diagram to replace thermal fuse in wmk 300 waring pro
The most common reason for thermal fuse failure is running the iron with the top open, especially when set to a higher number (longer cycle time) and/or not flipping the iron over at the strart of a cycle.
Keep it closed except during the 10-15 seconds needed when adding the batter or removing a waffle.
Thermal fuse 240C often available on ebay 4/$2 or Amazon 10/$7-$10
Feb 15, 2014 | Waring WMK300 Professional Belgian Waffle...
Waring pro popcorn maker not heating
use a non contact voltage detector pen and follow the wires from bottom up to bowl heater , somewhere along the way the power will stop , thats the device that needs some looking at
Mar 23, 2012 | Waring WPM25 Popcorn Maker
It won't heat up
Throw this piece of **** in the trash. My first clue that it was a piece of **** was when I saw that it was made in China. I used my Waring Pro Model # WMK 300 a total of 6 times and then it died. From what I am gathering on the Internet this is a very common problem with the Belgium Waffle Iron. When it worked it was incrediable but use it 6 times and it goes belly up, this is so ridiculous. I personally think they should take this Waffle Iron off of the Market. I finally found the parts list for this Waffle Iron it did show the replacement Heating Element, but they have made it unavailable because they feel it is unsafe for the consumer replace it they feel you are to stupid to replace the Heating Element without harming yourself, give me a break this is a very simple fix for the average homeowner to take care of. I realize there are lidiots out there who might not be mechanically inclinded enought to to this. I think the average handy man can do this without any problem what so ever.
Sep 27, 2011 | Waring WMK300 Professional Belgian Waffle...
Waring pro wc1000
Try plugging it into another GFI outlet. If it still trips, it's a problem with the coffee maker wiring and is cheaper to replace it than fit it.
Aug 25, 2008 | Waring Pro WC1000 Coffee Maker
A short condition has severed a conductor wire inside the coffee maker. Seems to be a common problem with coffee makers as the wires are in close proximity to heating devices.
Mar 16, 2008 | Waring Pro WC1000 Coffee Maker
Waring Pro WC1000: Pour over 12 cup coffee maker
Waring Pro WC1000 coffee maker replacement carafe is Waring WC1000CRF glass replacement coffee pot. Black lid and black handle.
http://www.bestreplacementpart.com/waring-pro-wc1000-replacement-carafe/
Feb 20, 2008 | Waring Pro WC1000 Coffee Maker
Waring pro waffle maker
I personnally just went through this.
If it is less than one year old, and you have the receipt, go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
My replacement had a silver body virsus the original black body. The shop told me they have yet had a customer repeat of this problem.
Jan 19, 2008 | Waring WMK300 Professional Belgian Waffle...
Waring WMK300 Professional Belgian Waffle Maker Logo
69 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
