Tonydixon63@yahoo.com Tony Dixon 63 530-209-8779
I have a dixon bass guitar that was my mothers. I want to know what it is worth.
Dixon were mostly known for making knockoff copies of more expensive name-brand models. So which one does this Dixon look like? Or, what's the Dixon model number?
Have a look on Google at 'bass guitar' and see if you can find the lookalike. Then we may be able to suggest a value, but it won't be over US$300.
Apr 11, 2017 | Bass Music
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
I need a left rear axle for a dixon mower it is bent so the chain jumps off, and a diagram of the rear assembly. It is blue with the levers between your legs, it has a 12hp motor. I am not sure what year...
You can eventually find your manual here:
http://www.dixon-ztr.com/node2171.aspx
There are a ton of manuals.... on that page. Looks like it will be a tedious hunt with out a model number.
If the link does not work go to
and click on support.
If you can come up with a part number you might be able to get it here:
http://www.lawnmowerpros.com/Dixon.htm
They also have parts manuals on this page:
http://www.lawnmowerpros.com/Dixon/Dixon-Parts-Diagrams.asp
Thanks for using FixYa.
Kelly
Mar 09, 2010 | Mtd LAWN MOWER PART # 903-0382 AXLE...
How do i correct my yahoo name -- it is sent as max coalson and i need to change it to tony coalson///
Hi Tony,
1. Login to your yahoo email account. You will be seeing an "Options" link at the upper right corner of your page. Click on that.
2. It will open you the General page. Just replace the name on the "From Name:" field with Tony Coalson.
3. Click on "Save Changes".
That's it!. Your Name has change and the next time you send message, it will appear From: Tony Coalson.
I hope this helps you. Good luck!
Sep 26, 2009 | Yahoo Mail
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
