Question about donjoylogo Donjoy Iceman Model 1100 cold therapy system
Pump not working, has power
Pump not turning on, the power cord has power. How do you get inside the pump housing
  • sean
    sean May 01, 2016
    Did you ever figure it out? I need to do the same thing.
How to take apart Intex 603 pump housing
You need to try 'security' bits. They come in sets with various sizes of star bits and hex bits.
Aug 18, 2014 | Intex 603 Krystal Clear Filter Pump 530...
Unit is loud
pumps will increase in there noise level as they age , this is due to parts that turn wearing down , eventually pump will fail to turn any more and require replacement , but that could be years later , one tip thought !! allways run pumps level not tilted they last the longest that way (its the way the mfg intended it to be used ) and not have a lot of stress put onthe pump housing with a tight hanging discharge pipe (support the pump not the pipe)
Jun 18, 2014 | Little Giant OPWG97 97 GPM Outofpond Pump...
My Little giant wgp-65-pw has tripped my gfi repeatedly. any idea why? No shorts in the cord are apparent
if a pump connected to a gfci outlet trips , then the gfci has detected a high resistance "shortage" inside pump and has disconnected power , this "shortage" can be nearly in detectable from human standards(shock) , but gfci picks it up
most likely pump seal has failed and water has gotten inside pump !! it only takes one drop to do this !!
Dec 24, 2012 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
We have a proline above ground pool pump. Model PE71 III V. Been working fine the last two weeks. We vaccumed pool and then pump just stopped working. We don't hear any noise....like there is no...
at home depot the sell a pen that beeps at the sight of voltage (sensor) 12$ good house hold tool to have.. check the cord running to pump see if the pen beeps when held against cord if its a 110 set up the pen beeps and youve the 110 V needed to run the pump if 220 V a bit different .. if left powered But not running in a few min, touch motor housing the metal part of this unit. is it hot as a grill (internal winding problem) or still cool .. Motors are a wear item like tires on ones car.. motors are inexp like 110$ for a 1 hp unit
Jun 04, 2011 | Hayward 3/4hp Super Pump Inground Pool...
I have- starite pump it was working fine last night but this morning there was no pressure at all i wonder if is the water tank the pump is running fine but there is no water
It sounds like you have blown your shaft-seal. When this happens the pump runs dry. If you know that you have water but it will not pump, and all the cover and housing o-rings are good, it is the shaft seal. (unless the internal impeller is just broke, but this is unlikely)
Fix: Turn off power. Remove V-clamp holding wet end together. Remove diffuser inside wet end (need flathead screwdriver).
next remove rear electrical panel on the motor. Using s 7/16" wrend, hold the end of the motor shaft by the electrical end (where you removed the cover) while turning the impeller counter clockwise (note: some impellers have an impeller screw inside which unthreads CLOCKWISE) untill impeller is off. Replace carbon shaft seal inside. Reverse and prime and then restore power and start.
Oct 20, 2010 | Sta Rite StaRite DuraGlas Pump 34 HP...
We have a GE front load washer WCVH6800. Recently we loaded some throw rugs into the washer. These rugs released a large amount of material. We cleaned the pump filter 3 times and it now seems clean. ...
The water inside the tub will drain out when the pump filter is removed from the pump housing and flood the base of the washer. If not, the tub drain hose is clogged preventing the water to drain into the pump housing then out.
The door is locked because the foam switch in the pressure switch is open due to the presence of water after the unsuccessful drain cycle.
Disconnect the washer from the power outlet. Remove the three screws holding the lower front access panel to the cabinet and pull the panel down to access the pump housing.
Squeeze the clamp that hold the tub drain hose to the pump housing and slide it back. Prepare a pan to catch the water to prevent flooding. The tub drain hose maybe difficult to remove and you may need to insert something under it to break the seal and pull it off.
Remove the tub drain hose from the tub by squeezing the securing clamp and pulling it off the tub drain outlet. Clear the hose and the tub drain outlet from any debris.
Reinstall the tub drain hose and manually unlock the door before reinstalling the access panel. Reach and pull the release ring behind and up the right side of the front panel, then open the door.
Feb 14, 2010 | Dryers
Pondmaster Mag Pump 1200 gpm has electrical short. When the cord at the pump is moved the pump goes off and on. Can I repair this? (i.e. can I get into the water tight case?)
You can get into the case ok but this is probally in the cord and getting that free from the caseing is the trick and then getting it back together so it won't leak is yet another. after some thirty years in the buisness I've found that due to exposure to the elements the cord you pull into the seal and the cord seal it self will not hold water for more than a few months and new parts wait time and aggrevation make replacement an option. But if it sounds like I'm saying don't try this, I'm not. What I am saying is if you try to fix it and it dosen't work don't feel bad, your not out anything but your time. If it works you win. When you take apart the back of pump you will find a rubber seal as you will find a comperssion seal around the cord. First usins a fine wet and dry sandpaper roughen the cord outside the pump and the rubber seal at the rear plate do not lube these. Pull some new cord through tighten compression seal at cord trim cord and rewire pump past weak spot caused by pump housing reset back plate tightening evenly and firmly but not so tight as to cause plate to warp. then tie off cord to some place on pump so if some one pulls on pump it isn't pulling on cord at houseing.
Jul 14, 2009 | Beckett Corporation Beckett Professional...
Ran out of gas,after putting gas it still wont start could it be the fuel pump? and where is it located?
did you check the fuel pump fuse and relay,if ok then fuel pump.fuel pump is located inside the tank,good luck let me know..
Jun 04, 2009 | 1994 Eagle Talon
Good power, tub will not turn
tub, is the lid switch plugged in? If not take a jumper wire and jump out the two ends on the harness. Timer controls recirculation and spin. The motor turns both ways. The spin cycle goes through the lid switch. Catriver..post back
Feb 27, 2007 | Whirlpool LSQ8000 Top Load Washer
donjoylogo Donjoy Iceman Model 1100 cold therapy system Logo
103 people viewed this question
Top donjoylogo Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a donjoylogo Health and Beauty Expert? Answer questions, earn points and help others
