Question about Whirlpool Dishwashers
My whirlpool dishwasher model du941pwkb1 tries to drain but makes grinding sound
  • 1073 Answers
SOURCE: kenmore dishwasher makes grinding noise while draining
disassemble the top of the dishwasher pump, remove the bottom spray arm and remove the screws on the top of the pump housing this will get you started
Posted on May 03, 2008
  • 93 Answers
SOURCE: Whirlpool Dishwasher suddenly making a grinding noise...
Motors for tall tub whorlpools are over two hundred dollars. If its less than a year then its under warranty. You did not indicate model. If you can get back to me I'll look more in to seeing if it is feasable to repair or replace.
Posted on Jul 24, 2008
SOURCE: GE dishwasher is making a grinding sound
http://www.applianceblog.com/mainforums/archive/index.php/t-2825.html
Posted on Oct 13, 2008
  • 64 Answers
SOURCE: LG dishwasher is making loud grinding sounds
debris in pump. unplug and disassemble pump. clean out and reassemble
Posted on Aug 26, 2009
  • 572 Answers
SOURCE: whirlpool dishwasher stopped in mid cycle
check your chopper inside ur unit.
Posted on Feb 11, 2010
Kenmore dishwasher 587
It seems it is drain pump problem ,clean pump and try it and if problem persist you should replace pump if needed
Dec 09, 2013 | Dishwashers
Dishwasher will not drain I think it:s the pump
It will help if you provide the make and model of dishwasher. There can be several reasons for dishwasher not draining. The most common is blocked filters or drain hose. Also ensure the kitchen side of drain is clear. If pump is running but making grinding sounds then something is blocking the drain pump. If you do not hear pump running sound then the dishwasher may not even be getting to the drain cycle for other reasons.
Apr 19, 2013 | Dishwashers
Dishwasher makes grinding sound during wash cycle.I cancelled and drained due to the sound.
This means that some debris is trapped inside the motor. You can complete this repair yourself, it's simple. Remove the lower spray arm followed by the screws on the top of the motor housing.
The impeller will be below the part that lifts off with the screws removed.
Appliance & Refrigerator Parts
Mar 22, 2011 | Whirlpool 24 in. GU980SCG Built-in...
I recently replaced the chopper in my whirlpool quiet partner III. now it won't drain. I can push the cancel drain button and hear the pump running, but nothing happens. I tried reversing the wires to...
It sounds like you've done a lot to try and fix your dishwasher. Make sure your air gap is not plugged up and double check the drain hose. If those are clear change out your drain hose. Part#8270145 the elbow connector sometimes have a bad check valve and could keep it from draining.
Hope that helps Thanks please rate me
Dec 11, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
A loud noise from the pipe that connects the dishwasher under the sink. Would that be a problem with the machine??
When the solenoid turn on to let water into the dishwasher and when it turns back off it can cause the pipe to jump. I will assume that it is banging into something. If so over time it could create a hole in the pipe or tube. I'd try and figure out what it is hitting and move one or the other things.
Sep 20, 2010 | Whirlpool Dishwashers
Grinding sounds
Grinding sounds that last for longer than 3 minutes at a time are usually an indication of something in the wash pump. If the grinding is only for about 2 minutes at a time it would be something related to the drain pump.
It depends on the make and model on how to clean out the pump or drain pump. If you happen to have a tall tub Kitchen Aid, Whirlpool or Kenmore this link has instructions on how to do that.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
May 01, 2010 | Dishwashers
Water remains in Whirpool Gold Quiet Partner dishwasher
sounds like an issue with the drain pump, disconnecting the drain hose fromm the trap and run the unit, pointing the disconnected drain hose into a bucket. You should get a fairly strong stream of water until most of the unit has drained, if not you either have a blockage or ,with the grinding sound, a bad pump.
Mar 11, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Jul 24, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Whirlpool Sound During Drain
Yes, you can pull one of the pump's leads to find whether the noise comes from the pump. You should unplug machine's power cable first and be sure that the disconnected wire is isolated. Before replacing the pump look that it clean from any foreign object/ Good luck!
Aug 17, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
