Phaser 6500 won't wake up - Office Equipment & Supplies
Xerox black developer fade printing
Try this: http://www.fortwayneprinterrepair.com/wordpress/2014/03/17/xerox-phaser-6500-workcentre-6505-light-print-issues
Apr 25, 2014 | Xerox 6500/N Phaser Laser Printer
Is there a service mode on the xerox phaser 6500 ?
To enter Service Diagnostics on Xerox Phaser 6500:
1.turn the printer off ;
2.press and hold both the Up and Down arrows and turn the printer on ;
3.when Service Mode and ESS Diag appear on the display, release the buttons. You will need a Service Menu Map to navigate through the menus, they are quite complicated.
Jul 03, 2013 | Xerox 6500/N Phaser Laser Printer
Changing waste container
The is no waste container on Phaser 6500. There is a "waste collection box" in every toner cartridge and the waste toner is discarded along with the empty cartridge. The is also a waste toner reservoir on the transfer belt and this one will be replaced along with the transfer belt.
If there is an error message saying, for example, "Waste Full Cyan Cartridge", it means the waste toner counter reached the replacement value for that color and you have to replace the corresponding cartridge. But the waste collection box is not really full.
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
My Xerox Phaser 8860 keeps waking and running during standby, is this normal?
The machine will try to keep its temperature at a constant level so this is normal. Also, if you have intelligent ready enabled, the machine will wake up at certain times when it thinks you are going to print. i.e. If you always use the printer at say 3pm to print out the days post, the machine remembers this and will wake at about 2.55pm and warm itself to a ready to print state.
Hope this helps.
Nov 18, 2010 | Xerox Phaser 8860MFP Printer
Have an officejet 6500 wireless printer and the printer goes to sleep and wont wake up without unplugging it
Power Save Mode.Just press the on/off button or wait for the printer to wake up when you start a print job.
Nov 07, 2010 | HP Officejet 6500 Wireless All-in-One...
I have an officejet 6500 wireless printer and the printer goes to sleep and wont wake up without unplugging it.
Nov 01, 2010 | HP Officejet 6500 Wireless All-in-One...
Xerox Phaser 8560MFP: When in sleep mode, the printer still wakes up to do a warm up test and then goes back to sleep. How can I turn this off?
Look in the setups.
It might be a good idea to print out the setup sheets. Look under sleep mode and set the time accordingly to what you want.
Alternatly go to the WWW.xerox.com website for assistance.
Good luck.
Oct 03, 2010 | Xerox Phaser 8560MFP Laser Printer
I own a phaser-8550 and the problem is that the printer seems to wake up when it is in sleep mode. If I turn it off and back on the next day, jobs print OK until it goes to sleep and it forgets to wake up....
There are two stages to the sleep mode, One is a low power condition. That is the real sleep mode. There is also a time that will shut the machine off. You can go into the machine setups and shut that timer off.
Mar 09, 2010 | Xerox Phaser 8550/SDT Color Laser Printer
Xerox phaser 8550 prints garbled characters
This happens to mine occasionally after I have put it into standby a few times. If I reboot this always sorts it out.
Apr 05, 2009 | Xerox Phaser 8550DP Printer
jasbo
jasbo
