Question about Nikon Superior E 7382 (12x50) Binocular
Need manual for superior fireplace model cf6-cmp
Need illustrated parts manuel fo superior fireplace model cf6-cmp
Need manual for whalen fireplace 41 long model#sf103-23
Search Results
    [PDF]Harrison Fireplace Console Model # HRSFP-30I - Whalen ...
    www.whalenfurniture.com/...instructions/Whalen_HRSFP-30I_Instructio...
    Harrison Fireplace Console. Model # HRSFP-30I. ADULT ASSEMBLY AND SET-UP REQUIRED. If you have any questions regarding assembly or if parts are ...
    [PDF]User Manual - Whalen Furniture
    www.whalenfurniture.com/...instructions/AI%20WS03061533%20Engli...
    Please call our customer service number and have your instructions and ...CATALOG: GRANTVILLE 64'' Media Fireplace (WS03061433/WS03061533).
Nov 28, 2015 | Cameras
Superior fireplace manuals
If you are looking for the owners manual then go to this site.
No Search Performed
Aug 19, 2014 | Heating & Cooling
I HAVE A HC3820 AND AM CURRENTLY LOOKING TO OBTAIN A BLOWER. THE PROBLEM IS THAT THE ONE NEEDED FOR THIS MODEL IS FAK-1500 AND I CANT FIND IT ANYWHERE! PLEASE HELP!
Honestly, go to www.grainger.com. Since Superior/Lennox Hearth/and FMi are all merging into one company you are going to have a very hard time finding replacement parts for older Superior units. Plus the new company, Astria Fireplaces, is going to be using FMI for their woodburning products so no more Superior products available.
If you bring the old blower to your local Grainger they can match it up. I hope this helps.
Jan 24, 2014 | Superior FBK-200 Fireplace Blower Kit for...
Superior gas fireplace model FAK-1500 owners manual
I have a superioir fire place in need of a manual foe model number fak-1500.
Jan 29, 2012 | Heating & Cooling
I'm looking for a user manual for a Superior Gas Fireplace model FAK 1500. I want to know how to take off the front glass as it has become covered in a white residue.
The fak 1500 number is for the blower assembly. I found this manual for a fireplace using the blower assembly. hope it is what you are looking for. Lennox has bought out the fireplace company and there are no manuals available under superior.
Feb 11, 2011 | Heating & Cooling
Need a manual (preferably a pdf I can print) for the Superior FAK 1500 gas fireplace.
The number you provided is for a blower kit. However, I was able to find a pdf for you that should describe your fireplace. See this link:
http://www.lennoxhearthproducts.com/resources/manual/725024%20NC-%20BCF_BRF_38_43(C&O).pdf
The blower kit is described at the end of the manual.
Mar 17, 2010 | Heating & Cooling
I am looking for an installation manual for Model FUBSK blower motor kit. We bought a new home and the Lennox Superior wood burning fireplace Model BC-36 has a switch that should force heat out into the...
The fan should be installed behind the bottom grill, and then it should blow air around the firebox which then exits out the top grill. Now saying that, let me explain the actual problem you will face. Because you have a open faced wood fireplace, you will not get the heat your looking for, the fire needs 400 cubic feet of air per hour and that air is taken from your opening. Also the inner box doesn't heat up enuff to produce alot of heat on the skin so if you have the fan blowing full blast, it will only cycle the air and not allow it time to heat up as it cycles around the box. I suggest turning the fan speed down so its 1/2 way on or lower, this allows the air time to heat while cycling around the box, but in the end you still won't have a good heater as the fireplace itself isn't one, you should look at having it converted to direct vent gas or ripping it out and replacing it with a airtight wood.
Jan 03, 2010 | Superior Lennox Blower Thermal Sensor -...
Nikon Superior E 7382 (12x50) Binocular Logo
42 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
