Question about SySTOR Systems 111 Target SATA Standalone CD DVD Duplicator Duplicators Disc Copier Copy Tower Burner
My systor system 5 tower cd dvd duplicator will not copy dvds
2 Suggested Answers
  • 902 Answers
SOURCE: Hi I have a 1 to 15 CD DVD Systor SATA 20x
sounds like you may have a loose connection on some of your drives i would open it up and check it out. also if it has a usb interface you can re download the firmware for this. you may wanna try and unplug it for a few minutes to refresh the system. let me know if tghat helps that what i found when i did research on your issue for you.
Posted on Mar 15, 2011
Copying dvd
You may take a look at this step by step guide, it will teach you how to copy DVDs to another blank DVD disc, it's easy to understand and works pretty well for me.
http://www.freedvdripper.net/guides/copy-dvd-to-dvd-shrink-dvd9-to-dvd5.html
Hope it helps. Contact me if you have any other question.
Dec 27, 2013 | Copystars Cd Dvd Duplicator Barebone Kit...
Hi I have a 1 to 15 CD DVD Systor SATA 20x Duplicator Burner Copier System who buys 5 months ago, but now when I turn the machine on but the display controller is lit but I do not see the menu, I can not...
Mar 15, 2011 | SySTOR Systems 111 Target SATA Standalone...
I have a stand alone dvd/cd duplicator at our church having trouble with. Cant copy onto dvd-r's. Master can be dvd-r or dvd-rw and will copy onto dvd-rw. when i try to copy onto dvd-r's, it will run for...
The two common problems, copier doesn't like color of discs etc, and slowing the speed that leave you've already tried. After those the most likely thing is that one of them has heads that are out of alignment. You could try copying cd's as they have coarser and the heads don't have to be as accurate. If that works then it is very likely it's the heads out of alignment. If they won't record on the cds at all it still can be the heads out of alignment too, but this test may help determine which drive is out of alignment.
Mar 06, 2011 | Computers & Internet
How do I use a 7 disk duplicator tower? Model 52X65x52x
Hi you put your dvd or cd into the top copier,put however many blanks you want copied into the burners below, you dont have to use all 7 if you dont want to make sure the control panal on the front says copy press enter and thats it.
Jan 24, 2011 | Tower CD&DVD Duplicator Cases: 8 Bays...
The controller only burns to 4 out of 5 drives and 1 of the 4 working frive keeps making burn errors. Is it time to install new firmware to fix this? or do i have to install new drives? Can i install...
Hi I have this problem with my systor 0-3 target duplicator, the one tray works fine, the middle one keeps making burn errors and the bottom one won't burn at all I can't seem to find a solution
Sep 20, 2010 | Vinpower 16x CD / DVD Duplicator with NEC...
Cannot copy dvds or cds with my duplicator
Hey! Usually, DVDs have some protections which prevent DVD users copying DVDs freely. Theser protections include CSS protection, region code protection etc. Therefore, you need to remove DVD protections first if you want to copy DVDs. There are some DVD Copy software which can do this. I have a good luck with this DVD Copy which works fine. You can have a try if you like.
Hope that helps.
Nov 07, 2009 | Plextor Dupsonic 52X 1 to 9 CD Duplicator...
My SySTOR DVD TOWER ONLY COPY SOME TIMES. I load
i would try changing out that drive that isnt working
Jul 21, 2009 | Computers & Internet
TEAC DVD Duplicator copies CD but not DVDs
your DVD ROM's lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working agaain but be careful remember that no power should be attached to ROM.
pls rate me
thankyou
Feb 19, 2009 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Accutower duplicator
accutower won't burn cd it says "no clear cd'
Apr 08, 2008 | Tower ACCUTOWER CD "Music" 5 Writer...
Telex DVD 7 tower Duplicator
it's not the heads that actually have the problem, it's the head guide that's sticking whenever it reaches those tracks mentioned. you need to open the drive initially to be able to repair or clean the malfunctioning parts. the read-write lenses be cleaned with cotton buds, and the stainless steil head guides be wiped clean and oiled.
May 16, 2007 | Telex SpinWise Seven Drive (301735000)...
SySTOR Systems 111 Target SATA Standalone CD DVD Duplicator Duplicators Disc Copier Copy Tower Burner Logo
Top SySTOR Systems Computers & Internet Experts
David Payne
David Payne
Are you a SySTOR Systems Computer and Internet Expert? Answer questions, earn points and help others
