Tv codes to program remote
Need codes to program universal remote for Toshiba TV
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
freetek
  • 5568 Answers
SOURCE: toshiba tv code for Zenith remote
Check the manual for your Zenith; many of the Zeniths (and many others) have a 'scan' mode you can call up, in which you can repeatedly press one key (^ for example), then the Power Button. That will force the remote to set every code it has available, step by step.
If you no longer have the manual, you may find it here or several other sites that offer these.
Posted on Apr 09, 2008
  • 8 Answers
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Posted on May 25, 2008
SOURCE: need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Posted on Aug 28, 2009
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Posted on Oct 19, 2009
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Dec 14, 2015 | Toshiba Televison & Video
I want to program a universal remote to my Toshiba TV VCR DVD combo TV but I don't know what codes I need
Most universal remotes supply a sheet with the codes you need to program them to your particular make and model. It can take a while to do. If your remote doesn't have the code sheet or your make and model isn't on there, you could try doing a manual search. Not knowing what type of universal remote it is makes it hard to say but usually, there is a manual function that will scroll through every code on the remote until it finds the correct code for your TV.
May 26, 2015 | Toshiba Televison & Video
I have a ge universal remote and have a toshiba tv dont know codes and how to programe it could you please help?
Which GE universal remote do you have? Does the remote use a 3-digit or a 4-digit code? To program most GE remotes for a TV, turn on the TV. Then press and hold the Code Search or Setup button until the indicator light comes on. Then press and release the TV button. Enter the first code available for your device. The indicator light should go off then check if the remote controls the functions of the TV. Repeat the above steps if the code doesn't work or doesn't control all the features of your TV.
The manuals and code lists for GE remotes are here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
Toshiba 4-digit TV codes are: 0159 0178 0109 0120 0181
.............0105 0049 0095 0170 0260 0358
.............0394 0924 0012 0095 0117 0141
The 3-digit codes are 170, 181 or 641 for Toshiba HDTVs.
Please note that the remote probably only has codes for devices that were released 6 months or more before the remote was programmed. If your TV is newer than your GE universal remote, you may need a newer remote.
I hope this helps.
Jul 06, 2011 | RCA Televison & Video
I need code for URC-3220 Universal remote control for toshiba tv/vcr in one.
I can help you reprogram your URC-3220 Universal Remote for your Toshiba TV/VCR Combo.
The Toshiba TV/VCR Combo codes are 1145 & 0845.
Please review my Fixya Tip posts for:
TV/VCR/DVD Combo Codes
Searching for the proper codes, or
Downloading the URC-3220 users manual / owners guide.
I hope that helps.
Apr 07, 2010 | Universal Remote Control Remote Control
Need code to program toshiba tv with Direct tv remote
I HAVE A TOSHIBA 32A33 TV AND JUST UPGRADED MY RECEIVERS AND REMOTES I CANNOT GET THE DIRECT TV UNIVERSAL REMOTE RC64 CODES THAT THEY HAVE PROVIDED TO WORK, ANY ADDITIONAL CODES ? PLEASE HELP
Dec 06, 2008 | Directv RC23 Remote Control
Need code or codes for my Philips Universal Remote to a Toshiba TV
please tell my what code for philips universal remote pm 435s?for my tv sanyo?thanks?
Aug 15, 2008 | Philips PM435S Remote Control
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
