Has no picture only sound then it started smoking. How do I get the picture to show again.?
Samsung hpt5054x/xaa
4 Suggested Answers
  • 6 Answers
SOURCE: Have sound but no picture on Samsung plasma
It's a pretty common problem. The no picture but sound problem is usually the y sustain board. I've replaced 2 on mine now. The 680uf 35V capacitors usually are bulging because one of the power transistors went and took them out. This has happened to both of the y boards I had. One time the failing y board took out the buffer boards too, and once it did not. The fix is super simple and anyone with even the most rudimentary knowledge of computers or electronics can do the labor yourself. You should do the simple stuff first by just doing a quick test with a multimeter. Just check the power coming to the y board. After that you can just remove the y board by removing 3 cables and like 3 screws. Plug in the new board and it's done! You can source the parts from a place like shopjimmy or discount merchant. 3 boards were like 200 bucks. 1 board is like 100 bucks. Labor took me 15min. Think about that the next time an electronics repair place charges you 1000 dollars. Of course they check everything (Yeah right) and warranty their work (I don't) but if you check the service manual it states that this is the most common repair. Look for the Canadian manual online. Hope this helps!
Posted on Feb 23, 2010
  • 6 Answers
SOURCE: HPT5054 50 in. HDTV-Ready Plasma Television: Samsung HPT5054X/XAA - No picture, Sound OK, Have ...
It's not the x main. 90% of the time it's a y buffer that goes out. It's usually the top buffer. 3/4 of the time the buffer takes out the y main board too. You cannot just replace the y-main or buffer because it will just burn out the other within seconds. Also about 1/4 of the time it'll take out the top transformer on the power supply too. The solution? First disconnect the power to the y main board. turn on the television and check the voltages coming off of it. Careful it's high voltage 208V! Remember it's DC too. Then disconnect the buffers from the y main board. You can try powering the y-main up to see if the little LED lights up. This does not indicate it's working though but it'll tell you if it is possible to fix. The fixes for these boards is only for electronics guys. It usually involves replacing 1-3 capacitors and 1-4 FET's. Since a bad buffer can take out a good y main in seconds it's usually recommended that one replace all 3 boards at the same time. It's a $250 fix. How do I know all this? I've now repaired 5 of these televisions. I owned one and spent close to 600 repairing it. I bought misc parts and broken sets online for months before I had 2 different repair guys walk me through the process of repairing them. I had so much cash tied up in parts that I bought 3 more dead sets and repaired them to justify all my spending. I've never had an x board fail. I've had EVERY top buffer fail. I've had all but 1 y-mains fail. and 1 lower buffer fail. I've also had the y buffer fry it's top chip, blow a capacitor and FET on the y-main, and fry the top transformer on the power supply before my eyes. It only took 5 seconds. Replacement of the 3 y boards will almost always fix the sound but no picture problem. Hope this helps!
Posted on May 26, 2010
TV #1
  • 129 Answers
SOURCE: Samsung plasma hpt5054x/xaa California no sound no
If you got no picture replace the buffer boards.
Posted on Mar 20, 2012
My 2008 Samsung 50" Plasma tv screen went black a week ago. Never had any issues with it until then. Turns on/off fine, sounds is fine, channels change, just no picture whatsoever. Model#...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 04, 2017 | Samsung Televison & Video
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
I have a Samsung Model HPT5054X/XAA 50" plasma TV. the picture went black but still have audio.I purchased a reman Y sustain board.The Y buffer boards looked good. Now when I reassembled the unit,st
Did it work with the Y-sustain board replaced? Likely if it did not work then there is an issue with the capacitors on the Y-sustain board and the power board. Check these caps for failure and replace them with the exact type. Likely the caps are blown and cause voltage loss in one or both boards.
Feb 01, 2015 | Samsung HPT5054 50-Inch Plasma HDTV
SAMSUNG HPT5054X NO DISPLAY PICTURES
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 14, 2015 | Samsung HPT5054 50 in. HD-Ready Plasma...
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Samsung hp-t5054 turns on and off and clicks as soon as you plug it in
you have faulty capacitors in the power supply. I repaired an exact model two months ago with the same problem. Shouldn't cost much for a shop to repair. If you have a friend or family member who can solder, you can fix it for under $10
Mar 26, 2013 | Samsung Televison & Video
No power on HPT5054X/XAA
My 1st question is, have you tried both the remote and the power button located on the TV? If the answer to that is "YES" then it's most likely going to be the PCB (power supply board). If that's the case, then there is good and bad news. The BAD... The original board (BN44-00160A)
has been discontinued. It can be purchased used for $40-$60.
Now, the good... There is a replacement that Samsung "says" works just fine. That board is BN44-00162A. That one is going to run around $150 for a new one.
Good Luck
Mar 10, 2012 | Televison & Video
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
