Question about Casio EXILIM ZOOM EX-Z600 Digital Camera
CAN THIS CAMERA CONNECT TO A WINDOWS COMPUTER VIA THE USB
CAN THIS CAMERA CONNECT TO A WINDOWS COMPUTER BY USB
I want to get pictures from my NIKON 5x camera to my pictures
connect the camera to computer via USB cable,power on camera and follow prompts on your computer.very easy if using WINDOWS.
Oct 17, 2015 | Nikon Cameras
I cannot connect Olympus SP500 via USB port to Toshiba Satellite computer using Windows 7. Error Message: The Software is unable to find Olympus digital camera connected to a USB port on your computer.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Aug 02, 2013 | Olympus SP-500 UZ Digital Camera
I cannot access pictures on my memory card when i connect the camera to my computer. its canon powershot sd750.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 12, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
PowerShot A85 Digital Camera: when I connect my camera (canon powershot a85) to ...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
May 16, 2010 | Canon PowerShot A85 Digital Camera
I get OXC000005 when i try to open the programme. the camera is fine but won't connect to the pc. windows vista
Hi, Usually when you connect your camera to the PC via the USB, the camera shows up as a drive in My Computer. From there you can open the device(drive) and browse through the files, copy or delete them. Connecting the Camera via the USB and copying the files this way will be slower, but you can still get the work done. If you want fast transfers,4-5 time faster, a card reader would be a good option.
Apr 12, 2010 | Samsung Digimax A503 Digital Camera
Have windows vista on new computer, no longer have CD ROm for camera. I am unable to access the software when I connect it through USB port???
The camera should be detected as a drive when the camera is connected via USB. Does it? You should be able to connect and copy your photos straight out like a USB drive.
Apr 26, 2009 | Pentax Optio 330RS Digital Camera
COOLPIX CAMERA 5200
You might be more successful if you provided a little more information. Is your computer a Windows PC or a MAC? Have you tried connecting the camera to the computer via the supplied USB cable? Assuming you're using a Windows machine, you can simply transfer the images using Windows file services, without needing to install any additional software. When you connect the camera to the computer via the USB cable, Windows recognizes the camera as a removable drive and assigns it a drive letter (e.g. drive G:). An icon for the "drive" appears in your MY COMPUTER window. (a) You double-click on the MY COMPUTER icon - (b) double-click on the drive ICON that represents your camera - (c) locate the folder where the image files are stored - (d) and simply drag the folder to your desktop (or wherever you want the images on your computer's hard drive). If you don't know what I'm talking about, then you need help with basic computer usage. If you're having a problem with the USB connection (e.g. the computer doesn't recognize the camera) then you should provide some more details about this problem.
Jun 09, 2007 | Nikon Coolpix 5200 Digital Camera
ERROR: code 28 -- Windows XP & USB 2.0
I'm unable to connect my western digital hard drive to my Windows XP computer via the USB port. When I check the USB 2.0 Controller in the Device Manager, there is a yellow exclamation mark (!) next to it. When I check on the status of the USB 2.0 Controller, the following message appears:
The drivers for this device are not installed (code 28).
What do I do now?
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
I'm cannt to connect my digital camera to my windows via USB port. after this, I received message : The drivers for this device are not installed (code 28), what can I do?
Thx...
Sep 21, 2005 | Polaroid PhotoMax Fun 620 Digital Camera
Casio EXILIM ZOOM EX-Z600 Digital Camera Logo
18 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
