Question about Pioneer FH-X700BT
Backlight Unit worked for six months. Now all illumination is gone. The unit still works but I can hardly navigate without seeing the display.
3 Suggested Answers
  • 78 Answers
SOURCE: navigation
I have found that copied dvd's don't always work properly and even the slightest blemish or scratch renders it inop also it is illegal to sell a copied disc as it infringes copyright, I understand that the genuine disc's are expensive but you get what you pay for.
Posted on Feb 26, 2008
  • 128 Answers
SOURCE: backlight dosnt work on the screen but the rest of the unit works
backlight is burned out repair should be about $150 through an authorized service center.
Posted on Jan 25, 2010
My lenovo laptop has a black screen
Hi
Can you hear beeps and the hard drive starting up?
Has the unit been dropped?
Without much info it sounds like it could be either the LCD panel or as simple as a connector coming lose between the board and the screen.
Sep 17, 2014 | Computers & Internet
Unit works fine but LCD display does not illuminate. Can be seen in a low ligfht room but it does not light up like it did for years. Do these LCD displays just die???
The older LCD's have backlights hidden behind the display that burn out over a period of time, this is a tricky repair because the unit needs to be stripped down and the covering removed. Soldering skills for most jobs will be required.
Jun 09, 2012 | Teac CD-X8 CD Shelf System
32" ALBA 15 MONTHS OLD.
I am afraid it sounds as though either your backlight or power inverter has gone faulty, may be worth contacting alba to see if they will honour the warrenty (unlikely but worth a go) otherwise maybe try your home insurance to see if its covered, failing either of these options, if you feel confident doing so, disassemble the tv and look for any signs of visible damage (capacitors leaking or any components looking burned or scorche, and replace. Try looking for any panel markings which will allow you to search for a price to replace the whole unit.
Unfortunately I cant give you and hard and fast cure, and it is very difficult to tell whether it is the inverter or the backlight has gone (having said that, if you are getting picture at the very beginning, it may suggest that the inverter is getting the power to the backlight ok, which may suggest its the backlight at fault.)
Hope this helps.
May 07, 2011 | Televison & Video
Display has gone blank so cannot tune. can this be solved without going to a repair shop? technila dab 206 digital radio
You are experiencing a backlight failure. A repair shop can repair the item (grain of wheat lamp).
Once the backlight is repaired, you will see the characters on your screen.
Apr 12, 2011 | Audio Players & Recorders
Same stupid problem green is on when plugged in i have sound to turn on with drums beating but no screen have only used the chargers provided when i bought the tom tom i havent even used it in probably 4...
If you have no screen on, then i think you might need to replace the unit and hopefully it is still under warranty. But if not try this, turn the unit on and look very closely at the screen, change the angles and see if you can see a very faint image, if you can, then the unit is working but the backlight display is not working. If it is the backlight display it could be caused by something as simple as a loose connection, or it could need replacement. Hope this helps
Jun 15, 2010 | Tomtom ONE GPS Receiver
Display only stays visible at lowest illumination
Sounds like your display's backlight is dying. Your scfreen is in need of replacement. The higher ther brightness setting the faster it quits working.
Sep 25, 2009 | Dell Inspiron 1100 Notebook
Advantium 120 (Display Pad is not Illuminated or Working)
try removing the touch pad/switch membrane and cleaning connections on ribbon cables. if problem still exists replace switch membrane.
Phil
Jun 11, 2009 | GE Advantium 120 Convection/Microwave Oven
No backlight on a cdm-7834
The only possible installation problem could be the illumination wire on the head unit. If this is hooked to a 12 lead it would dim the backlight. Try disconnecting the orange wire if it has one(I'm not sure if the 7834 had a dimmer lead). If that doesn't fix it the head unit will have to be serviced.
Sep 03, 2007 | Alpine CDM-7834
LCD screen back light doesn't work
Ditto - JVC KT-SR2000 backlight doesn't work (watched die yesterday), after 2 years, 10 months. Sadly JVC no longer represents quality.
Note: Original JVC KT-SR2000 was a fire hazard - defective from start - overheated hardly describes it. BestBuy replaced first month.
Feb 20, 2007 | JVC KT-SR2000 SIRIUS Radio Receiver with...
Pioneer FH-X700BT Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
