Question about Hitachi 35CX30B 35" TV
The tv works fine then all of a sudden will go to an all blue screen. I turn it off and on again and sometimes it works and sometimes it doesn't. Sometimes just letting sit fr a bit and the picture
Picture and everything else is good when it is working. The blue screen comes on after it goes to snow.
    Problem Solver:
  • 11 Answers
Change the blue drive output transistor...
Posted on Jan 20, 2015
techman
  • 3130 Answers
SOURCE: Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
Posted on May 22, 2006
  • 1153 Answers
SOURCE: Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Posted on Dec 21, 2007
  • 1694 Answers
SOURCE: hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Posted on Jan 06, 2008
  • 1694 Answers
SOURCE: snowy screen just pops up
Bad tuner in tv....might be possible to solder bad connect in
tuner...........T.
DOCTOR VIDEO
  • 131 Answers
SOURCE: intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
Posted on May 17, 2008
All four HDMI ports on my LCD TV failed all of a sudden, but VGA port still works. Why?
Corrupted firmware. A firmware update might be necessary. Contact the authorized service center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 09, 2014 | Sceptre Televison & Video
My sharp aquos has gone to a blue screen and message saying not supported, why has it done this?
Suddenly it is plugged into what? The TV only works when a signal is sent to it. The TV is probably fine, but of course it's the messenger. Must be where the problem is.
May 04, 2014 | Televison & Video
Cant watch tv through dvd play
Usually a blue screen means the external device isn't connected. Since it sometimes works, the first thing to try is a new connector lead, in case your old one is faulty
May 11, 2013 | Televison & Video
There is blue yellow color blur on the screen with cable or dvd
This problem is of "CONVERGENCE". You have to replace the convergence IC's which is better to buy a new one TV, Just contact any expert and replace the convergence IC's and your TV work fine again you need not to buy a new TV.
Thanks for using fixya.
Jul 24, 2009 | Toshiba 42H81 42" Rear Projection...
My Vizio 32" Flat Screen suddenly turned blue and "no Signal"
Check the cable connector. If it is OK then the turner has gone bad. Replace main board will fix it.
Feb 06, 2009 | Vizio L32 32 in. LCD HDTV
Tv pictures suddenly goes dark blue
the tube could be going out. Do you have a warranty on that?
Nov 01, 2008 | Televison & Video
Blue line
good day.
The case you encounter with your unit is just a minor one. Most often caused by loose contacts particularly in the horizontal circuitry. Try to have the circuit be resoldered.
response is highly appreciated.
chris
Mar 29, 2008 | RCA TruFlat 27F520T 27" TV
Olevia LT27HVX 27 just blue screen
I just had this same problem over the weekend. Is your TV hooked up via HDMI?? Mine was and i've been having problems with the tv image shrinking whenever i turn on the tv, so i would have to change the channel 1 or 2 times for the image to come up normally. On Saturday I went to change the channel and then all of a sudden I hearld this loud pop and when the image came on it was just a sky blue screen, I couldnt see anything, but I could hear the channel. So I disconnected the HDMI and hooked up the tv with component cables I had and now it works fine. I ordered a new HDMI cable just to see if it will work again. If not, i'm calling Olevia.
Feb 18, 2008 | Olevia LT27HVX 27 in. LCD Television
Sony KF50XBR800 Blue Shading
more than likely it is the optical assy. there are light filters inside and after using the tv for a period of time the glue on these filters fail causing the filter to fall. which is what you are seeing. sony has extnded the warranty on most of their optical assy to satisfy the consumers.
Oct 10, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Televison & Video Logo
90 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
