Question about Electrolux EW30IS65JS 30 In. Stainless Steel Slide-In Induction Range
Error code E15 Electrolux induction range
I getting a beeping and e 15 error code. I have disconnected power and reconnected but continue to get same message. Oven works but cooktop does not.
2 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Electrolux Induction Cooktop E36IC75FSS Error Code 41
    Hi Sue -- when you switched the breaker, how long did you leave it off before switching it back on? Generally, it's a good idea to leave the breaker off (or unplug the unit) for a full 30 seconds before switching the unit back on. If you did have it off for 30 seconds and the error code came on after that point, then it may possibly be a relay isse. That will more than likely require a visit from an authorized servicer to properly diagnose the cooktop. Hopefully the 30-second test prevails and the issue is resolved. Best of luck!
    Posted on Aug 29, 2012
    Stove top error code E 15
    Thank you for your post, friend!
    From my understanding your Electrolux range is displaying an error code of "E15". An "E15" code stands for the ESEC self-test failed. This might be an issue with your ESEC (Electronic Surface Element Control) board or ESEC-UIB (User Interface Board). Before seeking any assistance with a professional technician I would advise you to perform a reset on your range. You can perform a reset by disconnecting power from your range for roughly ten minutes. If that does not help resolve your current issue I would suggest consulting with a technician for repairs. Hopefully this information is helpful. -Matt
    Feb 15, 2015 | Electrolux Cooktops
    I have a Maytag MIR8890AS induction range and after 10-15 minutes of running either the cleaning cycle or the having the oven at around 400F, it will start beeping every few seconds for a long time. A
    new ovens and electronics have error codes programmed in, my new stove does, you need to call an electrician and tell them the exact beeping issue and this will give them an idea on what may be wrong. In the meantime see if the manual it came with has a trouble shooting or error code page, or go to http://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10562&langId=-1&storeId=10212
    Dec 16, 2014 | Maytag MIR8890AS 6.2 cu. ft. induction...
    Prestige induction cooktop showing error E4
    Good Afternoon friend, I appreciate your inquiry!
    Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
    If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
    Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
    What does electrolux stove induction error code E21 mean?
    Did u ever find out.mine is doing the same.ive searched everywhere and can't find an answer
    Jun 23, 2014 | LG range & stove induction cooktops...
    GE Monogram f160 error code?
    When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
    Touch the CONTROL LOCK pad.
    Disconnect power to the cooktop and then reconnect.
    If an F-code appears again, call for service.
    May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
    Induction error e6
    Hello it07002 - You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control) and/or user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
    May 07, 2013 | Electrolux 36" Electric Hybrid Induction...
    Electrolux E 95 code
    Hello Robert - Typically, error code E95 indicates a power voltage miscommunication to the main components of the unit. You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then I would recommend contacting a professional to proceed further.
    Apr 25, 2013 | Electrolux 36" Electric Hybrid Induction...
    Error message on my electrolux INDUCTION STOVE TOP
    Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
    Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
    My electrolux iduction cook top sends error across the whole bord when I put anythng on the inductoin burner
    You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
    Sep 11, 2012 | Electrolux 36" Electric Hybrid Induction...
    Whirlpool induction ceramic cooktop error E6
    my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
    Dec 15, 2009 | Cooktops
    Electrolux EW30IS65JS 30 In. Stainless Steel Slide-In Induction Range Logo
    131 people viewed this question
    Top Electrolux Cooktops Experts
    rugby prop
    paulcarew
    Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
