Question about Toshiba Televison & Video
Cannot change cnannel selection on remote. Channel stuck on 3
5 Suggested Answers
  • 85 Answers
SOURCE: ilo 32 in
Try the keys on the set I would think there is a menu key there on the set to help get you out of favorite channels. Universal remotes don't always work as thought should be and usually onthe the devices remote will access all functions. Is our remote dead or busted? Try opening it up look for bad solder on the circuit board clean the switch contacts on the the board it may just fix it
Posted on Sep 04, 2008
  • 10865 Answers
SOURCE: TV is stuck on one channel and won't change even with remote.
Ii would begin by changing the batteries in the remote. As they lose their power they will control some functions but not others. If that doesn't solve it, get back and we can take additional steps. i want to help.
Posted on May 23, 2009
  • 40 Answers
SOURCE: remote broke and now the channel stuck on 61 and
Try getting a universal remote and use that to change the channel.
Posted on Dec 23, 2009
  • 121 Answers
SOURCE: I have Dynex lcd tv
Try this web site http://www.google.com/aclk?sa=l
Posted on Sep 26, 2011
Can't change channels stuck on 4 tried scanning it but it goes back to 4
There could be a few possibilities for this .:
  • Change the "Input" setting on the TV to "AV" or "VIDEO". There is probably an "INPUT" button on the remote.
  • Find the TV/VIDEO mode on your tv or check the back of the cable box where your cables screw into the unit. There is normally a switch to select an output for channel 3 or channel 4. Your's would be on 3. It's just a matter of switching to 4 to make it work on your tv. More info on this here:
  • https://www.google.com/search?q=tv+channel+stuck+on+4&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari
Jan 28, 2016 | Televison & Video
Tv will not come back on
Did you try turning the TV on with buttons on the TV itself and not the remote?
Dec 30, 2007 | Televison & Video
My tv needs to be on channel 4 but I can't change the channel it's stuck on channel 3 what should I do
Why can you not change the channel? The only way to change channels is either on the TV directly, or from the remote. If neither work then you may need to get a new remote, or a new TV.
Nov 15, 2014 | Televison & Video
Need to change tv to channel 3 without remote!
go to menu and see if you have channel selection on go down thaT way. you should be able to program it in.
Feb 16, 2010 | Televison & Video
Sony KV-20S40 stuck on channel fix
I have just got a kv-20s43 and your best bet is to try to restore settings, here, To reset TV to factory settings, turn the TV on, Then, while pressing the reset button on the remote control, press POWER on the TV. The TV will turn itself off, then back on, the original settings wiill be restored... definition: ch. fix- 2-6: Select when you want to control all channel selection through a cable box. Select the appropriate channel(usually 3 or 4) and use the cable box's remote control for channel selection. VIDEO: select from available inputs when you have connected video equipment and you want your TV fixed to it.
Feb 01, 2010 | Sony KV-20S20 20" TV
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
Change channel lineup
1.) Press the TiVo button on the remote (at the top)
2.) Scroll down to "Messages & Settings" and press 'Select' on remote
3.) Scroll down to "Settings" and press 'Select'
4.) Scroll down to "Channels" and press 'Select'
5.) Press 'Select' on "Channel List"
6.) Pressing the "ENTER" button on remote will let you change Channel Line-Up
Aug 28, 2008 | Tivo Series2 TCD649080 Video Recorder
Channels
Sometimes the RC [remote control] has a MENU button that you can "bypass" any channel.Did you use the RC and 'delete' the channels by mistake?
Aug 15, 2008 | Sharp VC-A582U VCR
Remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Oct 02, 2007 | Toshiba 20AF44 20" TV
No Remote, Can't Switch to AUX
you can use the channel down button scan it until it reach cnannel 3, 2. then Aux.good luck.and to get the originald remote for your tv you can buy it at www.partstore.com it wil cost you about $42.00.goodluck.
Apr 01, 2007 | Zenith C13A05LG 13" TV
Televison & Video Logo
18 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
