Question about Epson Workforce 1100 InkJet Plotter Printer
Printhead stuck on right side - Epson Workforce 1100 InkJet Plotter Printer
This error indicates the Printhead was unable to tilt normally on its axis. Check for spilled ink around the printhead that prevents it from moving right to left. The printhead could also be stuck to the wiper blade if the printer was turned off during a cleaning cycle. If you turn the x-axis motor does it move the printhead forward and backward? Check the process drive gears for damage and ensure the gears are timed correctly. Check to see if ink has spilled on the head tilt gear train (left side of printhead)
Feb 02, 2014 | Xerox Phaser 8860MFP/D - Multifunction -...
Xerox Phaser 8860 Error code 07,010.43:38138
This indicates a process drive or printhead error has occurred. The printhead is stuck or is not tilting properly. Check that the process drive gear train is properly homed. Check for obstructions or ink spills around the printhead. (was the printer tipped on its side or moved while the ink was still hot?) Check for blockage in the purge tube. Verify the printhead travels smoothly from left to right. Check to see if the process drive gears assembly is loose (broken frame where screws are).
Jan 09, 2014 | Xerox Phaser Office Equipment & Supplies
The printhead is stuck in the tilted position, or is not able to tilt forward to the print position due to obstructions.
Has ink spilled around the printhead that is preventing it from moving? (you should be able to push the printhead from left to right) MAKE SURE THE PRINTER HAS BEEN OFF FOR 30 MINUTES BEFORE YOU TOUCH THE PRINTHEAD !!!
Is the printhead stuck to the Wiper Blade?
Check the process drive gears for damage and make sure they are aligned correctly.
Has ink spilled into the tilt gears assembly or on its drive train? (left side of printer)
Nov 12, 2013 | Xerox Phaser 8550DP Printer
Hi. Our 8560MFP has come up with the error code 07,010.43:93096, plus the message "power down error - head not parked" - is this something we could look at ourselves or do we need professional...
7,010.43 Printhead is stuck or is not tilting properly over the cam.
Initial Actions
• Check that the Process Drive gear train is properly homed.
• Check for obstructions or ink spills around the Printhead.
• Verify the Printhead travels smoothly from left to right.
• Check the Printhead Restraint Arms.
• If the problem persists, follow the procedure below.
Table 1 7,010.4x through 7,015.4x Troubleshooting Reference Table
Applicable Parts Wiring and Plug/Jack References
Process Drive, PL 4.0 Right Side Harness / I/O Control, Figure 8
Head Tilt Solenoid, PL 4.0 Left Side Harness (2/2), Figure 5
Head Tilt Gear, PL 4.0
Restraint Arms, PL 2.0
Head Maintenance Clutch, PL 4.0 I/O Board (2/2), Figure 10
Table 2 Printhead Restraint Fault 7,010.xx through 7,015.xx Troubleshooting Procedure
Step Questions or Actions Yes No
1 Reboot the system.Does the error persist? Go to Step 2. Complete.
2 Check the Printhead Lock Arms. Go to Step 3. Repair or replace Do the arms rotate correctly? the Printhead Restraints
3 Check for ink spills around the Printhead Go to Step 4. Remove ink spills or obstructions.
and Printhead Tilt Gears. The Printhead
should move when pushed left or right.
Is the area around the Printhead clean
and unobstructed?
obstructions.
Jul 04, 2011 | Xerox Phaser 8560MFP Laser Printer
I am getting an error message for my Pixma iP90 Printer and it is 5C00 can you help
5C00 is a purge unit error, the purge is the unit that cleans the printhead on the right hand side. If the printhead will come out of the right side, you will need to check for paper scraps caught in there, If stuck on the right you will need a shop to check it out for you so you don't break anything. You need to remove covers and printhead and check under the printhead in the purge unit.
Feb 22, 2010 | Canon PIXMA iP90 InkJet Printer
Hello, My Canon MP830 suddenly shut off when I told it to print a sheet. It will not turn on, and the print head is stuck to the right, and I can't move it. I left it unplugged for several days, but still...
When the carriage is stuck on the right there's not much you can do, When the printhead goes bad it keeps your printer from powering up. You need to either remove the printhead, or unplug the light color ribbon cables from the circuit board on the right side of the machine inorder to power up, and then change the printhead. QY6-0061-000 around $60.00
Sep 30, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP700 how do I remove/replace printhead?
turn it off and see if you can move it out by hand. it should not be that tight in the machine. good luck.
Dec 02, 2017 | Canon MultiPASS MP730 All-In-One InkJet...
WRONG CARTRIDGE and Printhead does not move MP780
your printer ink cartridge can not access (move to middle) when you open up the cover, you may try
1) try to open right side cover you move the cartridge by hand (power off) to middle position, then take out the cartridge and reinstall it then power on, the cartridge moving right, you may open up the cover again if the cartridge go back the middle position which means your printer works normal. still stop moving go next
2) check the cartridge initcial sensor at righe side, the cartridge moving to the end of right should be touch this sensor, find out it and check there is good touch (click) by the cartridge body. adjust the sensor position maybe needed.
3) cartridge is stucked sometime also check the cartridge moving rail hard moving, need to drop oil to lubricate.
Feb 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Epson Workforce 1100 InkJet Plotter Printer Logo
103 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
