Question about Rapco RA-825 Brake Lining Installation Tool
Diagram brak lines 1977 cj5 jeep
Description of brake lines installation 1977 cj5
What is measurement of a float level on a carter one barel carburetor on a jeep cj5 1977?
1977 now that is a blast from the past.
finding books that old is hard, but are sold in book stores.
but from Carter, and very very old jeep books.
4 engine then
and 2 Carters, i see.
232/258cu-in, with YF carb
here ill paste the words
"To adjust the float drop, hold the air horn in the upright position and measure the distance between the top of the float, at the extreme outer end, and the air horn casting. The measurement should be 11/4 in. (31.75mm) to 1973, 13/8 in. (35mm) 1974-78. Adjust by bending the tab at the rear of the float lever."
Nov 09, 2016 | Jeep Cars & Trucks
How to adjust float level on a carter one barrel car on a cj5 1977?
posted now 3 times
must we answer 3 times,
i answered it, from the book, 77 CJ5
its on the mitchells site, all that,
log in and read?
1978 Jeep CJ5. When brakes are applied interior, side marker, and park/running lights all come on. Where is the problem?
There is a short or badly installed light bulb in the rear brake light housing. Those bulbs use both running lights and brake light filaments and if a filament shorts to the other filament or they are installed wrong, pressing the brake pedal energizes the brake light and inturn the running lights.
Jul 20, 2015 | Jeep Cars & Trucks
1974 jeep cj5 amc 304 v8 solenoid wiring
We do not have wiring diagrams here at fixya, the manuals are copyrighted material I did find this one picture with numbered wires that may help you hook things up.
Sep 18, 2012 | Cars & Trucks
I need a steering column wiring diagram for a 1979 cj5. On the column side of the plug that goes to the steering column there are 8 wires. White, Black, Yellow, Green, Purple, Brown, Light Blue, and Dark...
Black horn ground
lt.blue left front turn
blue right front turn
brown hazard power
purple turn signal power
yellow left rear turn
green right rear turn
white brake light input
Feb 12, 2010 | 1983 Jeep CJ5
I just bought a 1979 cj5 jeep. Only thing wrong
You can go to autozone.com and register for full free online repair manual. It will have wiring diagrams, other diagrams, diagnostics, and much much more. You can find your wiring diagram here. I feel it will help you best.
Nov 18, 2009 | 1983 Jeep CJ5
I need diagram showing me the firing order for a 1977 CJ5 Jeep 304
CJ5 Jeep with a 304 engine
1 is the drivers side cylinder closest to the front of the vehicle.
1-----------------------2 3-----------------------4 5-----------------------6 7-----------------------8 DRIVER - PASSENGER
More details you can find in Autozone.com (free register).
Hope that helps.
Aug 27, 2009 | Jeep CJ5 Cars & Trucks
Leaking front drivers side brake line
Have some one step on brake while you watch for the leak. The fittings for the extention may not be the same as the OE line causing a leak.
Jun 26, 2009 | 1983 Jeep CJ5
1977 Jeep CJ5; Fuel issue. Can't get it pumped to
You can attach a siphon to the fuel line from the pump back to the tank and use it to detect any leaks in the line. You can also check the carb the same way, running it on fuel from siphon. If both check out OK, you can use an electric pump or replace the mechanical pump. Either should work providing that the "sock" inside the tank is not obstructed.
Jun 18, 2009 | Jeep CJ5 Cars & Trucks
Rapco RA-825 Brake Lining Installation Tool Logo
21 people viewed this question
Top Rapco Sport & Outdoor - Others Experts
Are you a Rapco Sport and Outdoor - Other Expert? Answer questions, earn points and help others
