Question about Baby Jogger 2010 City Select Baby Stroller By
Spring popped out of front wheel and steering is not easy
    New Friend:
Detach the wheel and fix it in a vice, taking care not to damage the axle.
Pull or pry the gap open and put the spring back in place.
I did it a coulpe of times, pretty easy once you know how to go about it.
Posted on May 01, 2016
  • Jessica Goodwin
    Jessica Goodwin Apr 25, 2018
    Mikkel - Do you have a video? I just spent an hour prying and pushing that the spring will not go back into place. I'm desperate. Can you offer any help?
Air bag clock spring replacement
You will have to remove your steering wheel to replace this. First disconnect your ground on your battery. Let the car sit for a couple minutes to make sure all charge is out of the wires. On both sides of the steering wheel, there will be to little square covers. Take those off. there will be a torque bolt behind these covers. Remove those. After doing this, your air bag on the steering wheel will be able to be removed. then your ill see a nut in the middle of the steering wheel. Remove this nut. The next step can be done in two ways. one you can get a steering wheel puller to remove the steering wheel, or you can grab a hold of the steering wheel on both sides and shake the steering wheel loose. This will work most of the time but may not. After removing the steering wheel your clock spring will be underneath it. There is either two or four screws holding this on. install in reverse order. When you put your steering wheel back on, there are marks on the rod and the steering wheel you will need to line up to make sure your steering wheel is straight. If you have any more questions, just ask me.
Jan 21, 2014 | 2005 Nissan Murano SL
Broken radio controls,(steering wheel)
easy and not so easy the part you need is the clock spring underneath you steering wheel.to replace it is the not so easy part,you will need a steering wheel puller and some tools.its doable.purchase new one so you will know what you are looking for.
Nov 24, 2010 | 2005 Pontiac GTO
1986 accord when shifting, giving gas or less gas power shifts?
Jack car up. Hold the front wheel with both hands in the 3 and 9 poistion. Try and rock it towards you and away. If it is easy to move the wheel bearings need replaced.
Take it to an alignment garage and get the tracking/alignment sorted. Are the inner edges of the tires worn?
Push down on the wing hard to compress the suspension and release, if one side returns slowly, new shock or spring is needed. See if you can spot any cracked springs too.
Jun 23, 2010 | 1986 Honda Accord
When I turn the steering wheel there is a popping sound when I'm just about as far to the left and sometimes to the right. I've been under there with someone turning the wheel a few times and I can't for...
It is either a rusty u-joint,or the strut/shock has a rubber or plastic piece the spring slides on when wheels are turned and when this keeps gunked up from road grime and rust the plastic or rubber fails to turn easy and then all the sudden breaks free when wheels are turned and the pop you hear is the strut spring snapping back,while it is annoying it won't hurt anything,but to fix it correctly you need to drop the strut and clean the upper plate and apply a good waterproof grease.
Jun 02, 2010 | 2000 Jeep Cherokee
My Pontiac Bonneville has a popping noise when i hit a bump i think its the tie rod ends i don't know if its inner or outer. How can i tell what the problem is and how hard it is to fix.
does it kinda sound like two peices of metal striking each other? most likely the outer tie rod end. the inner tie rod end wouldnt make a sound anything like that, it would snap and you wouldnt be able to steer the car very well.....regardless, this is easy to check. remove the wheel. the object directly behind your brakes is the wheel hub, directly behind the wheel hub is the steering knuckle. connected to the steering knuckle you should find the strut up top, a control arm on the bottom, the sway bar attaches towards the front of the car, the outer tie rod end connects to the hub on the side closest to the rear of the car. connected to the outer tie rod end is the tie rod, which is then connected to your power steering rack and pinion via the inner tie rod ends. you want to locate the outer tie rod end and examine it visually. is the rubber cracked, torn, or missing? if so, replace the outer tie rod end. you will need a 2 jaw puller to remove the old tie rod end, but removal and installation is EASY (i taught my wife how to do it in 5 minutes and she did it successfully in less than 10). depending on how far the jam nut is moved when replacing the tie rod, you may need an alignment after replacing it. if the rubber on the tie rod end looks fine, the noise is probably coming from the strut. when the struts are worn out, the strain of the vehicle bouncing is put on the coil over springs. after a while, the spring can become worn out as well.....this would create a "clunking" sound when going over bumps.....and, if the spring wears out too much, you MIGHT be able to hear a metalic popping sound when the struts reach the damper if the spring hasnt expanded that far yet (this is extremely unlikely tho, more likely than not, the spring would crack/break LONG before you hear this noise and the car would be close to undriveable......). regardless, out tie rod ends are roughly 12-15 bucks each and extremely easy to install. you might be able to find a parts store willing to loan you a 2 jaw puller, but if not they generally run 30-35 dollars....DO NOT ATTEMPT THIS REPAIR IF YOU DO NOT HAVE A REPAIR MANUAL THE LISTS THE CORRECT TORQUE SETTING FOR THE TIE ROD ENDS. if the bolt isnt torqued propperly, a) your alignment will be off and b) you run the risk of snapping the new tie rod end.
May 03, 2010 | 1999 Pontiac Bonneville
My daughter dropped coins in my steering wheel and it is causing the horn to go off randomly. Can i disconnect the horn temporarily? it is a peugeot 407 se (05)
Yes. open your hood, look at front of vehicle, you will see the horn. Unplug the wire.
You may be able to pull the fuse, but check that no other accessories are ran on that circuit too
Apr 18, 2010 | 2005 Peugeot 405
Tried earlier no success. Just replace heater core and as you know had to remove dash and steering wheel. Hard job but every thing went Ok and heat works well. I thought i had the steering locked when i...
If you had the clockspring on wrong and turned it, it is damaged now and needs to be replaced. Remove it and put the steering wheel on and turn to confirm. You need to disassemble and inspect.
Nov 21, 2009 | Jeep Grand Cherokee Cars & Trucks
1992 ford f150 4by4 power steering only easy to the left hard to the right already replaced the pump and believe i've bled all the air from system.
To bleed the right line turn the wheel all the way to the right with the engine running. Once all the way right hold the wheel and shut the engine off. Let it sit for several minutes and restart. See it that does it. If not pop off your center steering link. If the wheel turns super easy in both directions, check front end components.
Oct 12, 2009 | Ford F-150 Cars & Trucks
Baby Jogger 2010 City Select Baby Stroller By Logo
218 people viewed this question
Top Baby Jogger Baby Gear Experts
Lyle Siemens
Lyle Siemens
john h
Are you a Baby Jogger Baby Gear Expert? Answer questions, earn points and help others
