Question about SmartDisk FireLite 80 GB Hard Drive
No Firewire socket on my new Imac - SmartDisk FireLite 80 GB Hard Drive
Replace firewire port imac 27
You can't, the firewire hardware is on the motherboard itself. The only way to replace the firewire port is to replace the whole motherboard. If it's still under warranty take it to an Apple store and they should do it free of charge.
Apr 13, 2012 | Apple iMac Z0GF0005F Desktop
Which firewire cable for panasonic NV-GS4
You need a 6pin DIN to firewire convertor, or to USB.
Checkout fleabay.
Oct 01, 2017 | Panasonic NV-GS40 Mini DV Digital...
I have tried to connect my Canon XM2 to my IMac via firewire, but it is not 'seen' by IMovie, FCE or FCP, so I can't capture anything. Thanks
Open the System Profiler on the Mac and establish if the camera is connected to the Mac's firewire BUS. If not, try another cable and also test is the camera's firewire port is working. It's either a cable or socket issue. Some cameras require that the menu of the camera be set to output over firewire, check this as well.
May 05, 2011 | Canon DM-XM2 Mini DV Digital Camcorder
Hi I've connected a firewire cable between the handycam and my new iMac. iMovie/iMac doesn't recognise the connection. Are there settings on the Handycam that need to be made for transfer to the iMac?
No need to change any settings it will auto connected.Check your cable may be its faulty. Try other think to attached your iMC.If still not working then You Firwire driver not instal.
Oct 28, 2010 | Sony Handycam HDR-HC7E DV Digital...
I was using the ADVC300 on my old MacPro G5. I just got a new iMac Intel 27" and can not figure out how to connect the unit to this machine.. Do I need a different cable then the IEEE-1394 since I do not...
connect box to Mac via FireWire
The connection would be, analog into device, firewire to computer. Play the analog device and import into iMovie, Final Cut or other editor. They should see the signal and therefore import to a digital file. Check with System Profiler to see if it sees the firewire device. If your software allows playing to the firewire device, the ADVC300, then you can record to those analog devices.
Aug 24, 2010 | Canopus ADVC300 Bi-directional...
Imac 9pin firewire port does not recognize my Sony DCR-HC52
Perhaps a USB to Firewire dongle will help sort you out. As you have discovered those two are not compatible. To make it work, you MUST get a 4 pin card and install it, or the USB solution.
Mar 14, 2010 | Video Cameras
Ihave a Umax Power Look 1100 with 2
Hello, yes you will just need a firewire 400 (6 pin) to 800 (9 pin) cable as the new iMac no longer supports the 6 pin connector.
Jun 27, 2009 | Umax PowerLook 1100 Flatbed Scanner
Problem transferring video from JVC JZ-HD3E-Ek
the stills use the USB and usually video needs firewire, do you have a port marked ieee1394, i-link or firewire?
Mar 29, 2009 | JVC Everio GZ-MC200 Camcorder
My new Imac won't recognize my cannon zr65 camcorder help please.
Some FireWire cameras do not play nice with other FW devices. Try unplugging the LaCie drive and any other FireWire device, then connect the camera directly to the Mac. iMovie should detect it then.
Nov 21, 2008 | Apple iMac 24" Desktop
Sony DCR-TRV530 firewire connection not recogized on Mac; won't import or capture video
try to use USB wire and then install the driver to your pc. hope that helps you!
CHARCOIS
Aug 21, 2008 | Sony Handycam DCR-TRV530 Digital Camcorder
SmartDisk FireLite 80 GB Hard Drive Logo
23 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
