Question about Jensen Vm9214 Car Video Player
Unit does not work and has loud clicking noise
Loud popping noise after click of thermostat
Clicking noises are normal...banging noises are not. Replace the thermostat.
Dec 15, 2013 | Honeywell Heating & Cooling
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
I would suspect that it is not the valve making the noise. I would bet it is the thermal expansion of the metal that you are hearing. Other than that, I have seen cases where there is a flow control valve, and depending on its operation, when it opens or closes on spring power it will over shoot and make a loud clicking noise as the clutch overshoots. This will usually only be about 2-4 clicks though, and around pool equipment I doubt you would hear much of it. I would bet more on the thermal expansion. Kind of like the clicking noise you will hear after you have parked your car and the engine is cooling down.
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
I can not release the main component in my Saesco de luxe. Here a loud clicking noise when machine is turned on.
Hi
The loud clicking noise is a broken brew drive. This usually happens when you use the pre-ground button but put more than the level scoop into the brew unit. The brew unit can't compress the coffee and jams the brew unit which breaks the drive gears. Drive gears have to be replaced. I have some drive units complete.
Oct 26, 2011 | Saeco Magic De Luxe Espresso Machine
The air conditioner makes a loud sound when the ac trys to kick in. When i put it under fan it works fine and makes no noise.
Sounds like your compressor is seized/stuck and the unit needs a new compressor. If this is the case it should make a loud buzzing noise for a while and then click when it stops trying.
Aug 14, 2011 | Amcor Heating & Cooling
Epson SX100 Scanner makes a loud clicking noise!
On the back of the Epson Perfection 1660 Photo there is a lever that shows a lock and a unlock by where you plug in the wire to the computer. It must be in the unlocked position otherwise it will make that loud clicking noise and not work. Hope this helps.
Apr 07, 2010 | Epson Office Equipment & Supplies
Trouble with Mita Point Source Ai3010. Loud noise
The toner auger that feeds the toner is bound up inside of the developer unit. It is a long spring.
Mar 08, 2010 | Kyocera Ai3010 Copier
Loud clicking noise when turn on printer
I would check wherever possible for foreign objects in the printer. Failing that, a partial reset is available for your PSC 2410:
A partial reset can be done by:
1) Unplugging the power cord (you are already there!)
2) Press and hold the (#) key and (3) key while plugging the unit back in
Dec 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
50 in. HP plasma made loud pop noise and stopped working.
clicking is from the relays -- sound like the power board went out--
go to partstore.com
Feb 24, 2009 | Proscan PS50700 50" Rear Projection...
Unit constantly makes a clicking noise.
Electronic filters use static dicharges to filter the air. Unfortunately the make that clicking noise when they discharge. LG calls it a plasma filter. Clean both the regular and the plasma filter to see if that helps.
Dec 30, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Jensen Vm9214 Car Video Player Logo
23 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
