Question about Bissell Vacuums
Bissel heavy duty brush not working - Bissell Vacuums
5 Suggested Answers
SOURCE: Bissel Proheat 2x circuit board
Use this link: http://www.4cleanerfloors.co.uk/cgi-bin/product.pl?PID=1278118_amp;brand=Bissell_amp;model=_amp;part=
I had the same problem. Ordered a PCB from Bissel it took 2 weeks to arive. I fitted it, then it blew again, turned out the brush motor was short circuiting. Ordered a new motor it took 10 weeks. I have now had to order the second circuit board.
Over 3 months to get this vac fixed - my advice is - don't buy Bissels!
Posted on Jul 23, 2008
Testimonial: "TY"
  • 33 Answers
SOURCE: My power brushes on my
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Posted on Jan 18, 2009
Vac Belts
  • 701 Answers
You need to change the belt(s). You can find the belts for this model here.
http://www.vacbelts.com/bissell-proheat-belt-combo-pack.htm
Posted on Oct 22, 2009
  • 389 Answers
SOURCE: need manual for bissel powe steamer brush select
User Manuals can be downloaded from the Bissell website
Posted on Feb 07, 2010
Bissell heavy duty 9x cyclonic vacuum cleaner has loud noise when brush roller is turned on
Inspect the area around the brush roll. There may be something stuck somewhere in there. Remove the brush roll to see if the brush roll end caps will spin freely. If there is hair or debris restricting the brush roll may be causing noise.
Feb 19, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell heavy duty professional vacuum just "broke". It only works when handle reclined and brush on. It acts as if the brush switch is for power. Can I fix this or just throw it away?
Think you may need to call Bissell Consumer Care at 1-800-237-7691 on this one. But I think with a couple of parts (if cost effective) you could fix this.
Feb 12, 2015 | Bissell Vacuums
Bissel easy vac roller won't work
remove brush roll and clean any string, hair, or whatever from it. especially around the ends. you can also unscrew the ends and check for debris there also. when you put ends back on use a little wd40 to lube up the bearings. if that doesn't work replace brush and won't hurt to change belt
Feb 13, 2013 | Bissell Roller Brush 2037029 for Easy Vac...
I bought the Bissell Heavy Duty in Jan 2009 and now the brush will not rotate. I have gone through all the trouble shooting procedures and it still does not work. Is my vacuum under a one year warranty? If...
if the brush does not rotate when it is in use, chances are the belt is broken. Belts are common to break and should be replaced once a year under normal use. (once a week) and heavier use, more times per year.
If the brush itself is not rotating, meaning you took it out of the machine and it physically does not spin, then you may need to replace the brush with a new one. You can possibly get one at your nearest vacuum repair center.
Good luck.
Nov 19, 2010 | Bissell Vacuums
How to get the beater brushes to work
Your belt is broken or has come off the track.
Mar 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Need manual for bissel powe steamer brush select
Feb 07, 2010 | Vacuums
Jul 09, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
Apr 18, 2008 | Bissell Vacuums
Brush belt is very weak.
Brush Belt broken or disconnected. Very weak belt. Colossal engineering mistake by Bissell. Belt itself and its components are under way to much stress for the size they developed to perform their task. For Quality Control to let such an obvious blunder pass can only mean that it was intentional for reasons, Im sure, beneficial to Bissell and costly for the consumer. No telling how many people buy another entire machine when this rubberband of a belt breaks like it was intended. Bissell is not a consideration of myself or anyone I can enlighten.
Apr 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
Vacuums Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
