Question about GE Stove / Oven / RanHin WB10X10078
Oven Door Hinge WB10X10078 installation
How do you change the hinge
  • 43 Answers
SOURCE: Replace door hinge on JVM1533WD002
Door Hinge replacement requires a Microwave Radiation Leak Test be performed after repairs.I am surprised they would sell you the part knowing this. You should have this repaired by a professional for SAFETY sake.
Posted on Jan 28, 2008
jumptrout51
  • 3361 Answers
SOURCE: Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
Posted on May 23, 2009
aasc
  • 1606 Answers
SOURCE: I need to know how to change the door opening. What do I do with the wires in the hinge?
Since the wires come up thru thr hinge , you cannot reverse the doors .
Posted on Sep 23, 2009
barkencoa
  • 3463 Answers
SOURCE: top oven door will not close..appears left hinge
The problem will be caused the hinge spring being broken or weak.
The only solution is to replace both oven door hinges to ensure a satisfactory repair.
Trust this helps with your problem.
Posted on Dec 15, 2009
  • 13 Answers
SOURCE: replace the oven door hinge
Here's a link with the info on how to replace a hinge on a similar model--schematics for both are virtually identical--this link contains some images that should help along the way:
http://www.managemylife.com/mmh/questions/164631-how-do-i-change-the-oven-hinge-on-my-ge-jb960bb2bb
Posted on Jul 16, 2010
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
Door to oven does not close completely - how do I access the door hinge to check or replace it?
Open oven door. Flip metal holder down at hinge to lock hinge. Lift door with hinge attached up slightly and off oven. Reverse to re-install door, making sure notch at bottom of hinge is hooked in frame of oven properly.
Jan 02, 2011 | GE JTP45 Electric Double Oven
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
Removing the door from a thermador oven CT130
Usually you will find a hole in each hinge to hold the hinge open when removing the door.
It is impossible to fight the door hinge springs and remove or install the door.
One opens the door and puts a nail through the hole to keep the hinge open for each hinge.
Feb 20, 2010 | Thermador Ovens
Hinge, oven door #822144
Pull up on the door to remove it from the hinges.
Remove the pan drawer on the bottom. Remove the spring from the hinge to be replaced. Remove the hinge mounting screws. Remove the hinge.
Reverse this process to install the new hinge.
Jan 06, 2010 | Amana ACF7225 Electric Kitchen Range
Dcs oven door unhinged
easy to install the door,before to remove check it how exactly the position of the door its a clip typr,or get the manual to see the procedure,open the door,pull open then if u see the hinge we have small lock in the hinge u psh it up the lock then slowly close the door,be care bcoz the hinge is powerfull,if u close the door see the hinge how to remove the door.
tnx gerbee
Jun 23, 2009 | DCS RGS-305 Professional Gas Kitchen Range
May 23, 2009 | GE Ovens
Oven door
Hi thanks for the question. lay the door on the floor .the hinge must be locked before it can be installed back in the oven. each hinge has a locking clip . push down on the hinge and lock with clip . same on the other side. install door. push door down. unlock the clips. close door. to remove door. push door down. lock clips . pull oven door out . thanks the appliance doc
Aug 05, 2008 | Frigidaire FEF366 Electric Kitchen Range
GE Stove / Oven / RanHin WB10X10078 Logo
81 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
