Question about Bosch Water Heaters
My greenstar 25si/30si burner light is not coming on after a long power cut
We have just had a 3 days without electricity and now cannot start up my mother's greenstar 25si/30so LPG comb boiler. The burner on indicator light does not stay on and mains on/off indicator+fault light starts flasing after a short time. Do you have any idea what the problem is?
4 Suggested Answers
  • 5 Answers
SOURCE: worcester bosch greenstar 25Si?30Si pressure gauge showing high
a couple of things , is your filling loop disconected ? , and are all your radiators blead from air, have you got a high point where the air can get stuck in system say pipes going into roof etc you may need to fit a air release valve in line at highest point to remove the air from system , your boiler should be around 1.5 bar running preasure average setting . if you are constanly filling with water you could be exceeding the pressure valve limet which releases pressure from system this could be faulty ?
Posted on Feb 05, 2009
  • 145 Answers
SOURCE: We have no pressure on our Greenstar 25Si/30Si
YOU NEED TO CALL THE MAKER
Posted on Jan 08, 2010
When running the bath the water is hot for the first minute then becomes lukewarm for the remainder.
possible weak flow check screens in faucets or turn down pressure switch
Jan 04, 2018 | Water Water Heaters
Greenstar 30si
this is your safety valve letting by first try and check ur pressure bladder shud b 28lbs squr inch if it isnt pump up to 28 what happens if the bladder has no pressure then the water has no were to go but out through to pipe water expands when hot and thats why un have to top up the other problm is safty valve worn out needind replacment hope this helps u Susan
Sep 21, 2013 | Water Heaters
When spark start and burner lights up and spark finish gas cuts off (cut off valves) and burner stops . Why is that.
Hi there may be a number of factors involved with this appliance,
1. if you are opening a hot tap/faucet only slightly there may not be enough water flow to keep the burner alight. try turning on the tap alot at first then decrease the flow to your required amount
2. there may be a blockage or partial blockage in your gas supply.
3. water may have entered the casing and got into the electrical componenets of burner jets
And lastly if your Rheem unit is past its warranty & you can't get a service technician out to check it, then your last resort would be to get a qualified person to have a look at it
Mar 09, 2011 | Rheem Tankless Hot Water Heater...
The water pressure on my Greenstar 25Si Worcester Bosch combi boiler is so low that the shower won`t heat up. Can someone please tell me how to increaese the water pressure as there doesn`t seem to be an...
The boiler has a filling connection which uses a filling loop to connect the boiler to the mains supply for the initial fill and subsequent fills.
See the link below from the manual you can buy the filling loop connection online or ebay its a simple task to replenish the pressure. Worcester GREENSTAR 25Si Instruction Manual Filling The System
Feb 06, 2018 | Water Heaters
Pressure shows 0 psi greenstar 30si
open the water feed by raing the brass flat lever to 12 psi
Aug 02, 2009 | Water Heaters
Worcester bosch greenstar 25Si?30Si pressure gauge showing high
Feb 02, 2009 | Water Heaters
Water Heaters Logo
53 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
