Please could you help me to upgrade my qsat 116 satellite reciever
My HTC HD2 will not recieve satellite transmissions.. All the software works correctly and searches for transmissions. Data connection os ok. gps is managed automatically. It seems to be a harware...
Contact T-Mobile for support - 1-800-T-Mobile.
you may need to do a firmware upgrade or a factory reset. They will be able to help with both.
Apr 14, 2011 | HTC HD2 Smartphone
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
Our world space satellite radio could not recieve carr75
World Space currently telecasts only two channels, all others are shut down.
1. Sai Global Harmony - Free channel
2. Asia Development (Currently transmission is not available)
Please feel free to reach for any information, what ever is possible I can help from my side.
Thanks.
Ranga.
99400 54273
Jan 05, 2010 | Audio Players & Recorders
No Picture
check cable connections. make sure connections are tight... also if you have satellite press "input, tv/video, source, or a/v" button on remote that came w/ tv. also check to make sure tv is set to ch 3 or ch 4 depending on how the satellite box is set (it will be on the back of the satellite box)
Apr 04, 2009 | Gateway Televison & Video
I have eurovox max 2008
due to upgrade in the software of the eurovox and other recievers you will need to upgrade your box once you have done that power scan your box and it should be up and running.
Dec 01, 2008 | Audio Players & Recorders
Toshiba Satellite P105-S6024
Depending upon which CPU came with your laptop, you may be able to upgrade. The three options available for the P105-S6024 are:
  • 1.6GHz
  • 1.83Ghz
  • 2.0GHz
Each are Core Duo processors. I hope this helps!
Regards,
CharlieJ
[Please rate the solution, if this answer helped you.]
Nov 17, 2008 | Toshiba Satellite P105-S6024 Notebook
Unable to pick up satelites
hi
problem with my garmin 76csx .. the reciever shut down.. cause by pushing power and other botton while search my navigator find..
no help from my service guys i bought it from they suggest i send it in for service..
solution went to upgrade webpage.. and downloaded a software for the chipset..
system came back on line looking for satellites..
yahoo.....
Jul 04, 2008 | Garmin GPSMAP 76CSx Handheld GPS GPS...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
