Question about Zoom R8
Shows please power off
When turned on, it says please power off
Help me ASAP! my verifone VX810 doesnt functioning. it shows "PLEASE REBOOT" when i turn it on. i dont know what to do.
Each issuer/processor typicall adds their own software to the POS, so even though it is a Verifone terminal, you'll need to work through your bank/processor/issuer on the support end. If a power reset won't work, your support contact can walk you through a hard reboot.
Nov 14, 2014 | VeriFone Vx 810 Payment Terminal
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
The Samsung cash register ER290 shows E9 on screen
E9 : DISCONNECTION OF PRINTER, PAPER JAM
- Please turn the power off and fix the printer connector, turn the power on again.
- Please turn the power off and remove the paper in the printer, turn the power on again.
Oct 05, 2014 | Retail Supplies
My Acer extensa 5620Z laptop will not turn on
it seems your charger is not working, try to check it with another power adapter
Oct 23, 2011 | Acer Extensa 5620 Notebook PC
The power light shows on my lap top, but the
You may have a bad battery. Remove the battery and try restarting. If it comes on without the battery, you know that you need to replace the battery.
If that is not the problem, please report any sounds that you hear when you turn on the machine. If you are able to see anything on the screen, please report that too.
Jun 12, 2010 | Acer Aspire 5315 Notebook
When i start up my pc, the icons do not show - NOTHING shows... Only my wallpaper shows.. Not even my taskbar or desktop. Please assist
press Ctrl-Shift-Esc together WS Task Manager will come up .... click on File you will get the option for New Task .... click on it .... type in explorer.exe and click OK. if that does not work turn off your pc ... disconnect the power cable from the back ... press and hold the power button for 30 secs with power cable disconnected.... plugg the cable back in turn on the pc ..... issue resolved
Apr 21, 2010 | Microsoft Windows XP Professional
My screen shows lines and when I take a picture
Please reset the Camera and check if that helps.
To reset the Camera, just press the RESET button using a sharp-pointed object. The Reset button is located inside the jack cover. Please make sure that the Camera is turned ON while pressing the RESET button.
If the issue still persists, power reset the Camera and check if that helps.
To power reset the Camera, please remove the Battery Pack from the Camera and then press the POWER button for 15 seconds.
Then, reinsert the Battery Pack after 1 minute, then turn ON and check if that helps.
Thank You!
Apr 09, 2010 | Sony Cyber-Shot DSC-P32 Digital Camera
My dell dimension 2300 powers on,but nothing shows on the screen and i just got a brand new power supply for it.Also when i turn it on the power light isn't lit and it sometimes works.
Could you please post back with the status of four lights at the back of the system title ABCD. Also does the system shows the dell logo on the screen as and when the power light comes on.
Try removing the memory and disconnect the HDD and the optical drives from the motherboard and then power on the system. If the system comes on reseat all the above components one by one.
Thank You for using Fixya
Proton
Jul 12, 2009 | Computers & Internet
Zoom R8 Logo
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
