Question about Wildgame Innovations Wild Game Innovations - VU50 - Wildgame Handheld Card Viewer
Backlight screen goes black - Wildgame Innovations Wild Game Innovations - VU50 - Wildgame Handheld Card Viewer
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
When tv turned on will get apicture for only a few seconds then screen goes black, but wil continue to have audio. Cannot pull up menu on tv either
Hello.The screen goes black means that the backlights of your LCD is not working.Maybe the problem is the power supply or the driver board of the backlights.They shutdown because there have a shorted parts on the circuit or power supply. Did you try to reset the power and turned on and get a picture or every time that you reset the power it will get a picture and the picture goes black?
Jul 02, 2011 | Sanyo DP19649 LCD TV
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
Black screen
the broblem is either in the backlight of the screen or in the converter of this screen and you need one knowing electronics to change the backlight and check the board but it appers to be backlight
Nov 15, 2009 | Acer 22" X223w LCD Monitor
Used as second monitor suddenly stared to go dark
If the screen is lighting up for a fraction of a second when you turn on & then goes dark, this indicates a fault either with the backlights on the screen or the inverter part of the monitor. You can check the backlights if you have access to a backlight tester, you need to remove the rear cover & connect the backlight cables into the tester, if this checks ok then look for a problem on the inverter board, checking the capacitors for any signs of distress.
Aug 11, 2009 | LG W1934S-BN 19" Monitor
Screen goes black after about 10 minutes...POLAROID TLX-04240B
Simple Fix Repaire the backlight
repair man sure www.teexp.com
dont shoot the messanger!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 13, 2009 | Insignia 42" LCD Flat-Panel HDTV
Screen goes black after 30 seconds
Yes, this is a backlight problem. However, it could be either the light itself or the inverter that powers the backlight when it fails like this. I'd recommend replacing the entire screen plus housing and hinges (it is often sold as a complete unit) or just replace the inverter (often relatively cheap) and then if that doesn't fix it replace the screen (the backlight is non-replaceably attached to the screen).
The other option is to simply attach it to an external monitor and use it like that. This is also a free way (well, as long as you know someone that has a monitor) to make absolutely sure that the problem is the screen and not anything else.
Jan 19, 2009 | Dell Inspiron 8500 Notebook
Sony KDL-32ML130 lcd tv
Not really that tough. Sounds as though the backlight is shutting down, either from a power supply failure, or a failure of the backlight circuit itself. You can verify this by holding a flashlight to the screen in the area where the menu usually appears to see if it displayed on the LCD panel with no backlight. If you can faintly see the menu displayed, your backlight has shut down and the most likely cause is the backlight inverter board, followed by the power supply and the backlights themselves which are part of the LCD panel. If you found this information answered your questions, please be sure to rate it. Thanks!
Oct 24, 2008 | Televison & Video
Monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Nov 26, 2007 | Acer AL1711 17" Flat Panel LCD Monitor
Wildgame Innovations Wild Game Innovations - VU50 - Wildgame Handheld Card Viewer Logo
711 people viewed this question
Top Wildgame Innovations Games Experts
Pamela Leach
Pamela Leach
Camryn Johnson
Camryn Johnson
Level 1 Expert
Are you a Wildgame Innovations Game Expert? Answer questions, earn points and help others
