Car Audio & Video Logo
A
Anonymous Posted on Feb 15, 2014
What size fuse in a clarion apx2120 120watt amp
1 Related Answer
Anonymous
  • 6966 Answers
  • Posted on Jul 16, 2008
SOURCE: fuse for pwr amp.
For a single Clarion APX480M, the inline fuse should have a rating of 40 amperes.
Incidentally, perhaps a copy of the installation manual would be of use to you. One is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
2answers
What guage wire do i run to the battery for a clarion dxz655mp car stereo
I have no idea. Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
What size wires do i use for the DPX11500 please?
4 Gauge would be best (100mm2) but it will work on 8 gauge.
1helpful
Fuse apx200m
HI,
If the fuse is blowing of then there is problem with the inverter stage of amplifier. There is an inverter stage in the amplifier to boost the 12V to + or - 30 to 40V normally. Its a switching circuit normally uses Mosfets and ferrite core transformer and a driving IC. If the mosfet is shot then the fuse will blow off immediately after power is connected.
Check on thing remove the REM connection and then connect the power. If the fuse blows the there is fault with the Mosfet Its short.
If the fuse blows only when you connect the REM then the amplifier stage is faulty.
Also check by disconnecting the speakers. if any of the speaker is faulty then there is a chance for fuse blow off.
Ajin
Apx4360 clarion amp has no power to it no lights come on the head unit comes on just the amp has no power fuse are good
Do you have the Continuous power wire hooked up to the amp from the stereo? that will generally make the amp not turn on.
I bought a used '94 toyota celica st with a clarion RAX341D in-dash radio in it. I also has a Clarion RDC634 6-disc CD changer in it with its own in-dash CD-Changer controller (Clarion). My problem it,...
all the fuses including the ones behind the radio? if you tried that, try resetting the unit. there should be a little button about 2-3 mm in size either on the faceplate or behind it that can reset the system.
Fuse for pwr amp.
I need help
Make sure your ignition signal wire didn't come loose somewhere. Was the Amp exposed to extreme heat?
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
