Question about Optics
Mode button stuck on bushnell rangefinder
Mode button is stuck down.
frankmann
  • 47 Answers
SOURCE: bushnell quest er6
Here is what I could come up with:
There is no code list available, so check these things:
1) Low battery, replace if necessary
2) You are trying to measure an object that is too close, try a more diatant object
3) You are not holding the rangefinder steady and have not gotten a reading off the target. Try an easier, larger, more reflective target as a check.
4) You have an electrical problem requiring repair.
If you are still getting an error, contact Bushnell at 1-800-221-9035 for instructions.
Posted on Dec 13, 2007
  • 133 Answers
SOURCE: Bushnell Pinseeker 1500 Laser Rangefinder
All these units need an alignment....Vibration and dropping are slow death to Pinseekers.
Posted on Apr 24, 2009
  • 133 Answers
SOURCE: Bushnell Rangefinder Tour v2 E31 appears in viewfinder
If it is 2 years or less from the date of purchase.....send a copy of the POP (proof of purchase) or call them......! It should be under warranty. This is the real deal!!!
rate if you can!!
MTG
Posted on Jun 25, 2009
  • 133 Answers
SOURCE: i need replacement caps for my bushnell rangefinder
The model 20-0400 did not come with caps. It had a type of jacket cover.
call bushnell and see if they still have one left.
mtg
Posted on Jul 17, 2009
  • 133 Answers
SOURCE: Nedd battery cover for Bushnell Medalist
call Bushnell at 800.423.3537
ask them for one...about 7-8 bucks
mtg
Posted on Oct 08, 2009
WHY DOES IMAGE SHOW (FLAG) LEFT SIDE AND FOLLOWING BOTTOM OF VIEWER: 1 888 YM +18 D 888 BATTERY CHECKS OK SAME IMAGE APPEARS WHEN TOP BUTTON IS DEPRESSED.
Mine showed the same, found to be the mode button stuck in, removed button and used cotton bud with alcohol rub into the rubber seal, gave it a good clean and now as good as new. Hope this helps.
Nov 05, 2015 | Bushnell Tour V2 Pinseeker Laser...
Bushnell range finder #200800 dated 5/97
http://bushnell.com/manuals/rangefinders/20-0880_YP_Compact_800.pdf
Jun 28, 2010 | Bushnell Yardage Pro 800 Compact...
I can't get it to bow or rifle mode
Look on the back of the rangefinder......Its a very small strip that has the model number, serial number, and date of manufacture. If it sez.....20-1932 you have a "bow and rifle" rangefinder.....!!!! If it doesn't have model number 201932. You don't have that capability. Read your manual, check the unit for the model type.
Part 2: Try holding down the "FIRE BUTTON" for more than 5 seconds....see if the the "setup" comes across the display screen........(read the manual) The unit should have came with a ballistic disk. If you don't have one call Bushnell and get one. (800.423.3537) It has a lot of good info on it.
Good Luck to you David!!!
mr tech geek
dont forget to rate....
Jul 16, 2009 | Bushnell SCOUT 1000 Rangefinder
I have a Bushnell Medalist Pinseeker golf laser rangefinder. I recently replaced the battery with a 9V Duracell Alkaline, and now the Pinseeker mode is not working (it will not sight different targets) and...
The "Pinseeker" mode is a automatic mode Sometimes it uses it, somtimes it doesn't. It is designed to recognize a vertical shaft. (Pin) Now IF you hold the power button down....you can see if all of the LCD segments are burning. If the segments fade out later in the game.... (bad LCD) Make sure the Pinseeker mode it on...(flag symbol on the left) Hit the button on the side if you need to. IF it still doesn't lock on to pins, it needs an alignment.
MTG
Jun 23, 2009 | Bushnell Golf Medalist BUU0055 Rangefinder
Recently purchased ypc 600, no manual, on screen read-out is in meters. can I switch this to yards?
Two buttons on the top. The big one is the power/fire button, the smaller one is the mode button. Hold down the mode button for at least 5-6 seconds and it should switch to yards instead of meters. (Y to M)
Good Luck!!!
MTG
Jun 20, 2009 | Bushnell Yardage Pro 600 Rangefinder
Bushnell 1500 pinseeker with slope+/- to go from M to Yards
Hold down the "MODE" button until the "M" starts to flash......touch the mode button again till the "Y" flashes........then touch the "FIRE" button on top.....(square button) Then it will be set to read in yards....not meters.
mtg
May 16, 2009 | Bushnell Pinseeker 1500 Rangefinder
Wrong type of measurement showing
On most of the bushnell units you just hold down the MODE button for about 5 seconds and the unit should switch from yards to meters....or vice versa
Mar 13, 2009 | Bushnell X-500 Rangefinder
Meters to Yards
If the unit has a "mode" button, hold it down for at least 5 seconds and see if the "Y" comes up on the screen. Let me know if that helped...mtg
Mar 11, 2009 | Bushnell Yardage Pro 600 Rangefinder
MODE ACCIDENTALLY CHANGE TO METERS AND CANT CHANGE BACK
Press and hold the MODE button down for 5 seconds and "Y" will return to the screen.
Oct 12, 2008 | Bushnell Medalist Rangefinder
Optics Logo
148 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
