Question about iLO 3200 32 in. LCD Television
Connecting it to a pc
I have got  a 32" ilo and when i connect my vga to the dvi and my ilo says it has NO SIGNAL  what should i do?
  • 4,889 Answers
You should connect it using s-video not vga..if it doesn't work try DVI..You will need an s-video cable to do this..
Posted on Oct 27, 2007
How to use rca entertainment series 32 inch as pc monitor
Assuming that your RCA 32 inch tv has an HDMI or VGA input, all you need is the proper cable to connect the two units. If your computer has a VGA out (blue female connector) and so does your TV, you would need a male to male VGA cable. If your computer has a DVI out (white connector), you would need to purchase a DVI to HDMI cable. The combinations can me played around with depending on what connectors are on the back of the TV and what you have as an output for your PC.
Feb 28, 2011 | Compaq Computers & Internet
Where do I get a cable to connect my laptop pc to the DVI input jack on the Soyo 32" LCD TV?
You will need either a DVI-I to DVI-I cable or a DVI-I to HDMI cable. Your computer should have a DVI-I output or HDMI. You can not directly connect a VGA output to the TV. If needed, you can purchase a VGA to component (Y/Pb/Pr) converter.
Mar 15, 2010 | Soyo DYLT032C 32 in. LCD Television
Ilo 42'' says no signal on VGA when connected to a computer
Snap off/fully remove pins 11, 12, and 15 from a spare VGA cable and use this to connect the ILO tv. These pins are used for identification of the monitor by the PC. The video signal is now displayed perfectly on my ILO tv, in all supported resolutions.
Mar 11, 2009 | Televison & Video
Flat Panel Insignia 19
Lets see the cableing..
So you have a mac with a mini-dvi slot, you have a mini-dvi to dvi adapter, and then Dvi to vga adapter which connects to the tv?
The mini-dvi to dvi adapter doesn't have the analog VGA signal your tv needs. If I understood right.
Apple's mini-DVI to DVI-D cable does not carry the analog signal coming from the mini-DVI port on the Apple computer. This means that instead of buying a single mini-DVI cable from Apple and using a cheap DVI-to-VGA adaptor when you need VGA output, you must purchase another mini-DVI cable from Apple.
May 20, 2008 | Insignia IS-LCDTV32 32 in. Television
Hook computer to ILO tv
The best way is to buy a graphics card with HDMI output. This will dsplay your PCs desktop the way it's supposed to look, and will appear much sharper and clearer than using vga, as the output is digital to begin with. If you don't need to play the latest games, you get get one for around $30. Add a wireless mouse and keyboard and you'll be able to control everything from your armchair. You can also then use your PC to download and watch films etc from the internet..
Jan 06, 2008 | iLO V27DMBX Television
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
No signal
Weegee, Unfortunately you are trying to mix two different video types: VGA is an analog video interface found on most computers (except for latest with flat panel monitors, which are usually DVI). Your TV DVI interface is digital (although there is a DVI-A, which is an anlog DVI interface, it is unlikely that your TV has this). So, what you are trying to do probably won't work. I assume your computer does not have DVI output (otherwise you wouldn't have bought the adapter), but some monitors have VGA inputs; does yours? What kind of DVI adapter did you get? Is a DVI-A? Check out http://en.wikipedia.org/wiki/Dvi for info on DVI interfaces.
May 12, 2007 | iLO 3200 32 in. LCD Television
Connection to a computer
This TV has an HDMI interface, not DVI. If your source is DVI, you can get an DVI to HDMI adapter. The HDMI carries both video and audio data, so you will need to connect your audio separately.
May 10, 2007 | iLO 3200 32 in. LCD Television
Problems connecting computer to tv via dvi
Not sure if you have fixed your problem or not. When I hook up my pc to the ILO 32 HD...I ran DVI input for picture...you can also use HDMI if you like..I had a problem with sound and had to use a splitter and run sound into AV2 IN to get sound for some reason...your no picture...if you are getting a black screen, you need to set the resolution on your pc. VGA to 640x480 and SVGA should be 800x600 and XGA should set at 1024x768..most likely the last one is the one you need..and this is not a normal pc res....set your refresh rate to 60HZ. All this is done in the control panel/display/settings tab. Also remember that you need to change your source on the TV to the proper connection to see it...ie component, HDMI etc.
Apr 02, 2007 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
88 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
