Question about Leki Camping, Backpacking & Hiking
How to turn off the anti shock feature - Leki Camping, Backpacking & Hiking
When should I use the anti-shock hiking pole?
The best anti shock poles are the Leki Makalu Anti-Shock Trekking Poles. They have an internal spring that absorbs the shock on rough ground. They also have telescopes from 28 to 56 inches for packing and adjusting to users and terrain.
Sep 04, 2012 | Coleman Camping, Backpacking & Hiking
What is a hiking staff?
Hiking staff is a single pole that's most effective when used on relatively flat terrain and with little or no load on your back. They are adjustable and some of them can include the anti-shock feature. Some hiking staffs may include a built-in camera mounted under the handle.
What is a standard hiking pole?
Standard hiking poles don't have the anti-shock feature and they are lighter and less expensive as a result. While they don't absorb as much impact as anti-shock poles when going downhill, they do provide a similar level of balance and support.
What is an anti-shock pole?
The anti-shock poles offer internal springs that absorb the shock when you walk downhill. In most anti-shock poles you can turn off the anti-shock feature whenever you like. The anti-shock feature is recommended if you have weak or damaged ankles, knees or hips.
How do i stop my 2002 GMC Safari from swaying
If this excessive swaying is due to worn suspension then those worn parts will be tie-rods, shock struts, anti roll bars and the rubber bushings holding the various parts of the suspension in place. General suspension overhaul would be required.
Now if its a normal feature of the vehicle you can improve the handling by fitting harder anti roll bars(sway bars), stiffer shocks, custom tie rods, better quality rubber bushes (polyurethane) and by lowering the suspension with shorter stiffer springs.
I suggest searching for an owners club for your vehicle where you should find some people who are doing the same thing and get advice from those who have been there before - --- You can ruin a cars handling and make it quite dangerous by changing things around, I suggest you search for suspension modification and do a quick 101 of the do's and dont's of suspension modification before you start swapping parts.
Jan 25, 2010 | 2002 GMC Safari
Have a g shock casio watch . want to turn off auto elluminate feature.
If you go to their web site (world.casio.com) you will be able to download a manual after entering the module number on the back of you watch.
Jan 05, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
TRYING TOO BY PASS ANTI-THIEF DEVICE ON 2000 CHEVY VENTURE,NEED ANSWER ASAP
If you're talking about the alarm, it's in the programming. There are 4 modes, depending on your model.
Mode 2 has delayed illumination, auto door lock, last door close/lockout detterent
Mode 3 has all those plus remote driver's door unock
Mode 4 adds the remote lock/unlock confirmation, content theft, content theft arming/disarming
Enter progam mode by
1. remove the BCM PRGRM fuse from the instrument panel fuse block.
2. Close the driver's door.
3. Turn the ignition key towards you, to ACC
4. Count the number of chimes you hear. You will hear two to four chimes depending on the features your vehicle is equipped with.
You are now in program mode...
With the content theft-deterrent system, if anyone damages or enters your vehicle whie the system is armed, the horn will shound and your parking lamps will flash for two minutes. The content theft shock sensor detects if anyone damages your vehicle. The shock sensors sensitivity can be adjusted by your dealer if more or less sensitivity is desired.
Mode 1: damage detection w/ reduced sensitivity
Mode 2: damage detection off (alarm only sounds when door is opened)
mode 3: feature off
mode 4: damage detection with Normal sensitivity
To change modes, enter the program mode, turn the parking lamps on and off, count the number of chimes you hear, that is which mode your vehicle is in. you can change the mode by turning the parking lamps on and then off again. Repeart turning lamps on/off untill you hear the numer of chimes you want.
The mode is now set, you can either exit, or program another feature.
To exit, turn thekey from acc to off and put the BCM PRGRM fuse back.
Oct 17, 2009 | Scosche Industries Scosche Gm05b Wiring...
Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Vibration of camera
Camping, Backpacking & Hiking Logo
96 people viewed this question
Top Leki Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Leki Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
