Question about Samsung Refrigerators
Where is the drip pan on samsung french door refrigerator?
hotuna
  • 288 Answers
SOURCE: How do I empty the Drip Pan
Remove the grill underneath the doors. A flashlight helps, look for a plastic pan, it should just lift out. Some of the older models the pan is bolted down. If you still cant find it, slide the refer out and take the panel off the back, some are easier this way.
Posted on Dec 26, 2007
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
docjohn174
  • 943 Answers
SOURCE: refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Posted on Sep 11, 2008
  • 117 Answers
SOURCE: condensation dripping from top of refrigerator
The problem is the defrost drain trough is plugged with ice. You will have to turn off the refrigerator, remove the freezer back panel and use a baby aspirator to help you apply and remove hot water to melt the ice. Then insert the aspirator in the drain hole to blow out any thing that may have gotten lodged inside. You will hear the water draining now to the pain underneath the refrigerator. Hope that helps you, good luck!!
http://tclaundryrepair.com/
Posted on Feb 25, 2009
Sea Breeze
  • 4654 Answers
SOURCE: emptying drip pans on a samsung refrigerator
I can give you the service manual if you like but what I think you are asking is how to stop the water from dripping inside your refrigerator. If I am wrong please explain and I will change the subject. Here is a link to the problems I think you need to solve. This is a very common problem and has several reasons that may cause the problem. I have a lot of information that covers the different ways that this takes place and how to to resolve the problem all on one page. So read the complete page and choose the part that most fits your refrigerators condensate overflow. Thanks, Sea Breeze
Click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Posted on Aug 16, 2009
How do I clean the drip pan
You have to pull the refrigerator from the wall to gain access to the rear panel. Remove the screws and look to see the drip pan. Do Not Try To Remove! Big pain in the but, and you will probably break something in the process. You have to be creative what you use. Try a rag or paper towels on a stick to try to wipe the mold and what ever is in there. Then put a cap full or two of bleach in the drip pan to kill any remaining mold and discourage growth of new mold. Your refrigerator will defiantly smell better. Assuming that is why you are cleaning the drip tray.
If this helped help us by joining our Google Plus page.
Thanks
On Time Appliance Google
Jun 30, 2015 | LG LFC23760 Bottom Freezer Commercial...
I have a Samsung model RF4287HA French door refrigerator. Has anyone had success cleaning the drip pan located at the bottom rear of the refrigerator? I know that this pan can't be removed, but I can'
Hello Derek;
My name is Peter. I am a retired field service refrigeration technician.
In answer to your question, the drain pan is removable. This drain pan is available for purchase. The problem is both Samsung and LG are not service friendly. The drain pan is not secured with fasteners and just lifts up.
However, There is the interference from the seal system (refrigerant) tubing and compressor which prevents you from pulling the drain pan out.
On my service calls with drain pan leakage, I just repaired the drain pan with duct tape an silicone adhesive. Because I could not get the drain pan out with out moving the compressor.
Both, Samsung and LG are the worst service friendly and highest cost for repair.
Jan 19, 2015 | Samsung RF4287HA 28 cu. ft. French Door...
How do I clean drip pan on LG French door refrigerator?
Does it not sit on top of the compressor? Behind the unit, at the base. Check for spilt milk, too.
Dec 21, 2014 | LG LFX31925SB
Water leak at the bottom of the refrigerator
The evaporator pan in the bottom of you refrigerator may be out of place, damaged or missing. there also may be a problem with the drain tube being bent and not dripping into the pan. It is also possible that the drain tube could be clogged and water could be collecting in the bottom of the refrigerator and spilling out too.
Jan 10, 2014 | Samsung RF265AA Bottom Freezer French Door...
How do i replace the cracked drip pan in the french door refigerator
  • Unplug the refrigerator from the power source and remove the decorative vent cover at the bottom of the fridge under the door. Some vent covers are screwed on but many just snap onto clip that hold them in place.
  • Pull gently on the exposed front edge of the drip pan and ease it out towards you. The drip pan slides on runners on each side of the bottom of the refrigerator. It may be full of liquid or debris so go slow and steady and then discard it.
  • Line up the new drip pan with the two side guides beneath the refrigerator and slide into place. Use the flashlight if to make sure the drip pan is in the groove on each side.
  • Clean and replace the vent cover by clipping or screwing it into place. Plug the refrigerator back into the power outlet
  • Dec 15, 2013 | Freezers
    Kenmore elite (795.75544401)is suddenly dripping water from the bottom of left french door.
    Hello and Welcome to FixYa!
    The dripping water could be from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit.... The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. Another cause may be the refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something like that, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the water disappears the problem is solved.
    Best of Luck,
    Please do Rate the solution, if you feel that this helps you,
    Concerned.
    Aug 18, 2010 | Kenmore 24.8 cu. ft. Trio French Door...
    I have a kitchenaid refrigerator kbfs20et that leaked
    Yes it can and it also can confuse refrigerators with electronics. Think it is great you caught on the first time around. I have pictures of that happening to a Samsung and there was Ice in places I had never seen before. Yes if the refrigerator is near defrost and you leave the door open it will continue to try to cool and the compressor will run until the temperature is finally satisfied and the amount of water will be huge and overflow the condensate pan. Sea Breeze
    Mar 15, 2010 | KitchenAid Architect® II KBFS20ETSS...
    Refrigerators Logo
    953 people viewed this question
    Top Samsung Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
