Question about Radio Communications
Cobra sr900 scanner the volume wought turn up sow I can hear it
Volume dont turn up has no volume
SOURCE: dont know how to turn the volume up on this headset
turn your headset off. when you turn on yourheadset back on , push the volume you wish to control the volume with. this buttom you choose shound be your volume up button now.
Posted on Jan 24, 2008
  • 12 Answers
SOURCE: low volume and problems with squelch
Check your speaker for a short.
Posted on Aug 14, 2008
LG_Authority
  • 65 Answers
SOURCE: how to turn up the volume so i can hear the other person
I think you have to use the jog wiel at the front of your camera
normaly you use it to zoom in and out.
With phonecalls, multimedia, radio and mp3 player you
use the same function to set the volume level high or low.
I hope this will help.
Posted on May 03, 2009
SOURCE: zone 2 volume control
Sounds like the Zone 2 amp was set to external, see below for instructions on setting it back up.
How do I setup Zone 2 on the RX-V661 Using the internal power amp.
Setting the RX-V661 remote control to operate Zone 2
1. Using a ballpoint pen or similar object and press the Code set
button. The Transmit indicator on the remote should flash twice.
2. Using the numerical key pad on the remote and key in 9992, the
Transmit indicator should flash.
You will now need to assign the receivers internal amp for Zone 2.
1. Set the remote control selector to AMP. Selector is on side of remote.
2. Press the Set Menu Button.
3. Arrow down to Manual Setup.
4. Press the Enter button.
5. Arrow to the Sound Menu option and press Enter.
6. In the Sound Menu arrow to Speaker Set and press Enter.
7. Arrow to the EXTRA SP ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
8. Press the Return button to exit out and return to the Manual
Setup.
Posted on May 24, 2009
  • 370 Answers
SOURCE: I cant hear anyone need to turn up volume
usually the up and down or the right and left scroll keys are defined to turn the volume up and down. Make a call to say hotline and then try the keys and see whether it shows the volume up and down graphic
Posted on May 01, 2010
Receiving volume is very low, I have to turn the volume up all the way to hear anything (squelch is very low when I turned knob to readjust settings) when before I didn't even need to turn it up halfway to...
was the radio wired direct or with a cigarette lighter plug? try the RF gain knob and the mic gain knob.If they are wide open does the radio rec.any better? if not you may have a problem with the main IC
Jan 04, 2014 | Cobra 29 LTD CB Radio
Volume low on cobra sk 900 scanner
check if the unit has a connection for an external speaker as this could help.
Apr 23, 2012 | Radio Communications
Samsung gt-e2550, how do you turn call volume up or down.
You can only adjust the voice volume when a call is in progress. There is no menu option.
When you are in a phone call, press upwards on the central 4 way navigation button (the centre circle).
This will turn the call volume up.
Jan 03, 2012 | Samsung GT-E2550 Cell Phone
What is dynamike gain cotrol on a cobra cb radio
Dynamike Gain Control varies the microphone sensitivity. When set fully clockwise, it is very sensitive - and will be able to "hear" background noises easily. This position also can cause your voice to be distorted or garbled when approaching maximum under the right conditions as well as causing "bleed over" to adjacent channels. When set to minimum, you will need to speak clearly and directly into the microphone to be heard. Most people find a setting somewhere in the middle works best.
You should adjust the level to suit those that are listening to you by asking them if it sounds OK. This prevents them from having to turn their volume down whenever you speak. In a "one-to-one" conversation it is not as noticeable. The trouble comes when 3 or more are conversing. The third person's audio may be low or normal - and the listeners set their radio's volume so that they can hear that person easily. Then you transmit with booming mic audio and everyone scrambles to turn down the volume to save their ears / speakers. This can be very frustrating for the others having to constantly adjust the radio volume whenever you speak.
I hope this helps and good luck. Please rate my reply - thanks.
May 18, 2011 | Cobra GPS
I cannot hear anything from my cobra cb anymore, just makes a humming sound. not too familiar with the settings either
Turn the radio on, turn the squelch knob all the way to the left,turn volume up, flip the switch to cb,not to pa,turn rf gain to the left,flip switch to normal,turn channel to 19,make sure the antenna is connected and mike is plugged in,can you hear any talking? If not let me know for further information. hope this was very helpful..
Apr 01, 2010 | Cobra 29 LTD CB Radio
Cobra 2000
Unplug it,and remove the cover. Hook it back up and turn it on. Take a pencil with the eraser end and gently press around where the volume is soldered in the circuit.Wiggle the volume knob,listen if volume change. Sounds like a cold solder joint.Re- solder the joints to volume,or could be a dirty control, if still no volume, turn off and spray inside of volume tuner with contact cleaner. hope this helps..
Mar 30, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
How can i connect the volume of my radio
Do you have a Microphone plugged in? No Mike No sound on these.
May 23, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra Police Scanner won't accept my frequency codes
when entering your codes make sure you put in the . or it will not take the number, most times the . is after first 3 # then hit enter then prg. I hope this helps.
k.ditterline@yahoo.com
Mar 09, 2009 | Uniden BC80XLT Handheld Scanner
Low volume and problems with squelch
Jul 06, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
