Question about 2001 - 2005 Mercedes-Benz C320 Bicycle Rack 910XT Mercedes-Ben
C 320 mecedes the coolant fan keep runing without start the engine
No error code displays on the dash board
    Master:
  • 442 Answers
When vehicles have electric cooling fans, the computer in the car may run the fan even when the car is off to try and help cool things. This happens frequently when parking after driving for a while when it's hot outside. It should turn off on it's own after a short period of time.
Posted on Sep 09, 2014
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
What does the error code PO119 mean on my 2013 arctic cat 500 atv mean
From Repair Pal:
Auto Systems and Repair
Engine Coolant Temperature Circuit Intermittent Our emissions expert has put together the following information about the P0119 fault code. We have also included diagnostic procedures you can take to your repair shop if the mechanic is having difficulty analyzing the code.
OBD II Fault Code
  • OBD II P0119
Fault Code Definition
  • Engine Coolant Temperature Circuit Intermittent
What does Mean?The Engine Coolant Temperature Sensor measures the rise and fall of the Engine Coolant Temperature. This provides critical data needed for the Powertrain Control Module (PCM) to control the Air Fuel Ratio, the Ignition Spark Timing, the cooling fans, and many components of the Emissions Control Systems. The Engine Coolant Temperature Sensor converts the coolant temperature into a voltage that is high when the engine is cold and low as the engine warms up.
Code P0119 indicates an intermittent voltage input from the Coolant Temperature Circuit to the PCM.
Sep 16, 2014 | Arctic Cat 2013 500 TRV Core
Overheating
OVERHEATING CAN BE CAUSE BY MANY THINGS LIKE FAULTY THERMOSTAT AND FAULTY RADIATOR PRESSURE CAP,TOO MUCH WATER IN COOLANT SYSTEM NEED 50 / 50 WATER AND ANTIFREEZE.LOOK FOR WATER PUMP WEEP HOLE LEAK, IF COOLANT LEAKING OUT WEEP HOLE WATER PUMP BAD NEED REPLACING.CHECK FOR LOW COOLANT LEVEL, YOUR RADIATOR OVERFLOW JUG SHOULD HAVE COOLANT AT THE FULL COLD MARK IF NOT KEEP ADDING COOLANT INTO COOLANT OVERFLOW JUG UNTIL COOLANT STOP DROPPING AND FULL COLD MARK, IF OVERFLOW COOLANT JUG WAS EMPTY RADIATOR IS LOW ON COOLANT.WHICH CAUSE AIR IN COOLANT SYSTEM KEEPING THE ENGINE COOLANT TEMPERATURE SENSOR FROM BEING SUBMERGE IN HOT COOLANT WHICH TURN ON THE COOLANT FANS.WHEN ENGINE COOLANT TEMPERATURE GET CERTAIN SET TEMPERATURE LIKE 190 DEGREES THE PCM AND COOLANT SENSOR WILL TURN ON COOLANT FANS, IF VECHICLE OVERHEATING COOLANT FANS NOT WORKING EITHER YOU HAVE FAULTY ENGINE COOLANT TEMPERATURE SENSOR CHECK COOLANT FANS FUSE AND RELAYS. YOU CAN CODE SCAN CAR TO SEE IF YOU HAVE FAULTY PCM, FAULTY ENGINE COOLANT TEMPERATURE SENSOR OR FAULTY COOLANT FAN RELAY.IF COOLANT FAN AND ENGINE COOLANT TEMPERATURE SENSOR OKAY,YOU HAVE CORRECT COOLANT LEVEL IN COOLANT SYSTEM, THERMOSTAT AND RADIATOR PRESSURE CAP BEEN REPLACED, YOU COULD HAVE BLOWN HEAD GASKET CHECK ENGINE OIL LOOKS LIKE MILK SHAKE HEAD GASKET BLOWED ALSO WHEN HEAD GASKET BLOWED YOU CAN DRIVE CAR SHORT DISTANCE START OVERHEATING AND YOU LOOSE ENGINE POWER SUSPECT BLOWED HEAD GASKET.
Aug 04, 2011 | 1999 Oldsmobile Alero
How do I best replace a heater core in a corsica 1995
You will have to drain all engine coolant.Disconnect your battery and your two heater core hoses that are on the fire wall in the engine compartment.Now inside the car start removing your dash.one dash is removed you will have to open you heater box to gain access to the heater core once you have gain access remove and replace.Now start replacing heater boxes dash board and reconnect heater core hoses and reconnect battery.Now top up your engine cooling system with the engine antifreeze drained you should have a extra jug of coolant in case you spilled or just needed it to top up.Now start car make sure coolant is full when cooling fans come on put rad cap on you have completed the replacement of your heater core.
Dec 27, 2010 | 1995 Chevrolet Corsica
When i drive 1990 maxima when i step on the gas peddle i hear like water running in the front of the dash board why
low coolant ,you have air in the system check radiator itself .filling the overflow tank wont get the air out of engine.run eng without cap until coolant cerculate or fans come on ,add to top ,close cap
Dec 01, 2010 | 1990 Nissan Maxima
No heat coming out fan blows but no heat
there's a blend door actuator behind the dash. they are going bad all the times. however, check your coolant level first.
Feb 28, 2010 | 1996 Lincoln Town Car
Lga motherboard no display, processor doesn't heat
if your processor does not heat up it's probably dead.. try running it without the fan and see if the heat sink still doesn't heat up
Sep 07, 2009 | ASUS P5V800-MX Motherboard
Car's overheating
Check to see if your radiator fans are working. If you have A/C just turn it on and both fans WILL come on unless there is a problem ie: bad fuse(s), relay(s), or motor(s). I don't mean to scare you, but, someone "could" have a pretty bad head gasket leak and still not see fluid come out of the exhaust. If the fans are both working, it could be any number of things from, a faulty coolant temp sensor, a faulty dash gauge, possible air bubble in the cooling system. Another easy check is coolant consumption, if you are leaking coolant into the cylinder while engine is running and/or into the crank case. Just check to see if your coolant level is going down and/or your oil level isn't growing because of coolant filling up your crank case. Hope this info helps...(subytech)...
Aug 07, 2009 | 1998 Toyota Corolla
Air in cooling system
if you have air what i can recomend is to turn the air conditioning on make sure the radiator fans are on and with the a/c compressor still runing set the cold and heat inside the dash board to the hotes and leave the car runing and keep addind 50/50 mix ANTIFREEZE TO THE RADIATOR UNTIL IS FULL you need to keep there until teperature is normal and no more air trap
May 31, 2008 | 1998 Buick Century
2001 - 2005 Mercedes-Benz C320 Bicycle Rack 910XT Mercedes-Ben Logo
76 people viewed this question
Top Thule Vehicle Parts & Accessories Experts
L Pfaff
L Pfaff
Rocguy
ray012965
Are you a Thule Vehicle Part and Accessory Expert? Answer questions, earn points and help others
