Question about Sony KLV-32M1 32 in. HD-Ready LCD Television
Flickering with audio pops, sony wega klv-32m1
Screen is dim, and flickers on and off - and at each instance of flicker there is an audible popping sound from the speakers.
  • 3 Answers
SOURCE: TV Flikers and StandBy Light Flickers
If your red light (Stand By) flushes 6 times - most likely your PDP is dead. Did you hear loud noise just before your TV went off? (like gun shot). If yes, then some chip (or chips) mounted on flexible ribbons (connecting PDP to other components were blown up). I had this problem few years ago. And since this time my TV is just peace of junk (needs drivers-ribbons replacement).
Posted on Nov 25, 2007
SOURCE: picture flickers
Check your power supply. Is it plugged in to the wall or a powerstrip? You might be overloading the powerstrip. Could be a source signal problem. Does this just happen when watching cable TV or does it do it on dvd's as well? Through the PC it is probably the viseo card,try reducing the resolution output from the computer.
Posted on Jul 01, 2008
  • 188 Answers
SOURCE: FLICKERING PICTURE
Check power supply for the 24Volts connected to the backlight inverter ,bad caps could be the fault
Posted on Jul 20, 2009
SOURCE: my sony xbr5 flickers until warmed up
brennanrp, I hope you purchased a warranty on your TV. My 46 in xbr-5 was doing the same thing. I called the store I bought it from and they took it to a repair shop. The panel inside, basically the inner workings are faulty and Sony has put an extended warranty on it. Get it looked at as it will only get worse. Soon you will probably be seeing some vapor like images across the screen if you have not already. the lines starting showing up even after extended viewing times.
Posted on Jan 29, 2010
electronick
  • 505 Answers
SOURCE: Picture has double screen with lines and also
Sounds like a bad LCD panel, these would give like horizontal lines and double images below.. Sony said it was the TCON board, but that is part of the panel. Call sony cust. service and complain about the issue, they were extending the warranty for such failures as the got a bad batch of LCD panels.. if sony doesn't help it will cost over $1000 so get them to help and they should, they're a good company.
1-239-768-7684
they will want model #, serial #, and date of purchase before helping you.... make a good guess on the DOP if you don't know it, other #s on back of tv
Posted on Jul 27, 2010
Vizio SV47XVT 47inch Screen flickers and makes popping sound through speakers what do I need to replace.
This is a power supply and/or possibly inverter(s) board bad capacitors. Since the audio is affected it could be both. Be aware that attempting to repair it yourself could cause irreparable damage to your TV.
Feb 08, 2015 | Vizio SV470XVT 47 in. LCD TV
Screen flickering
A number of possible reasons--from brightness/contrast set too high to a issue with the power supply of the set--a expert would have to examine the set--you might want to call Sony to see if known issue with this model.
Oct 29, 2012 | Sony Grand WEGA KDF55E2000 55" Projection...
Screen Flicker/Speaker Pop on one HDMI
Look for loose contacts in jacks, sockets, cables. Look for loose contacts in power outlet.
Aug 03, 2012 | Toshiba 32AV502U 31.5 in. LCD HDTV
Two problem don't know if they're related. I'll sometimes get the dreaded loud POP and then no sound when playing from our cable box or Ipod, I'll lose sound on the speakers in the main room but I still...
I have the same two problems! "Zone 2" works, but the main amp will make a noise and then stop working. Sometimes when I change the listening modes around it will start working. Lately, though, "zone 1" has gone out altogether.
Jan 12, 2011 | Onkyo TX-SR603X Receiver
Hanns-G HG216D is flickering to black screen
Started working after I d/l the driver
http://cms.hannsg.net/onweb.jsp?prod_no=3333333617&webno=33333333:0
Jul 31, 2009 | Computers & Internet
Sony KLV-32M1 LCD TV switches off/on
in this situation autoshutt off in few seconds no sounds and pictures. you have to check the secondary power supply. check all capacitors. budged capacitors can make shutt off sytem. capacitors blown on top due to hot pressure inside tv.
Jul 08, 2009 | Televison & Video
"Flickering" screen
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 15, 2009 | Toshiba Satellite A105 Notebook
Sony KLV-32M1 32 in. HD-Ready LCD Television Logo
42 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
