Question about Sakar 50 In 1 Pocket Usb Hi Speed Card Reader & Writer - Cr-72
The Sd card is in the slot and the adapter doesn't work on my computer
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
The sd card is too small. It doesn't fit into my computer, it came with a little yellow thing to attach to it but it doesn't work on my computer. Help.
Hello akamacho,
It is possible that you have a "MicroSD card". Most card readers can not read micro sd cards because it is too small, so you will need an "adapter" to be the same size as a normal SD card and then you can use it on card readers. I am just assuming (because I can not see it) that the yellow thing you have is the adapter. Make sure the micro SD card is inserted into the adapter properly and make sure that your adapter is inserted properly into your card reader.
If it is still not working, tell me the brand and model of your computer or you card reader. Also indicate any markings you can read from your sd card and the little yellow thing.
You can rate my answer if you appreciate it.
Thanks!
-damneddle
Oct 07, 2011 | Cameras
How do you put your micro sd card in the computer?
if theres a slot for an sd card on your computer you need a micro sd card adapter. if it doesnt have an sd card slot you need to buy a usb memory card reader (making sure it takes a micro sd card first)
both are widely available in supermarkets/electrical outlets or on ebay/amazon/play etc and are very inexpensive.
(micro sd adapter)
(memory card reader)
Aug 02, 2011 | Kingston 4GB Secure Digital High Capacity...
How do you transfer a photo from computer to sanDisk
Please keep the sandisk in to the USB port of system/laptop,
select the files what you want to send to sandisk, then rightclick on the selection. Then goto "Send to" option. In that you will find your sandisk. Select the drive of sandisk.
System will send the fiels to memory card.
Jun 08, 2011 | SanDisk 4GB microSDHC Memory Card
Computer doesn"t start keep rebooting
Try moving the card to a different slot.
Swap slots with another card if all the slots are full.
If this doesn't work, post a reply / add a comment to this post and I'll dig deeper for more options, but in most cases like this, using a different slot or swapping slots with another card will most often fix the issue.
Jun 04, 2011 | D-Link DWA-552 (ASKU56185) Wireless...
My 1 gb micro sd card is corrupted and my nokia E63 phone and DELL inspiron is not recognising it
    • 1 If your aim is to repair a corrupted SD card so that you can use it to store files then proceed to step #2.
      If your aim is to recover the files on the SD card without erasing them, proceed to step #5.
    • 2 Insert the SD card into a digital camera card slot and choose to format your card. If this doesn't work then move on to the next step...
    • 3 Place the SD card into your computers SD card slot.
      Right click on the SD card drive letter IF it appears and choose to "format."
      If this doesn't work, proceed to the next step...
    • 4:You will need to go to the website
      http://www.sdcard.org/consumers/formatter/eula/
      Here you will download, install, and run the program to format your SD card. This is the most advanced step of the three, but most likely to work 99% of the time.
    • 5
      If you want to recover files ON your SD without erasing them, then you need to download and run the software on this site.
      http://www.cgsecurity.org/wiki/TestDisk_Download
      This is the best free software available for this type of problem.
Jun 02, 2011 | Maxell 4 GB Class 6 Micro SDHC Card with...
I put the microcard SD into the usb 2.0 adapter. Then it shows that the removable disk is there on my computer. But when i click on it, it says please insert disk into drive G. disk is in there and it wont...
The USB adapter will be shown as different drives (depending on how many slots the adapter has) even if there is no SD card in the slot.
That being said, if the card is in the adapter, it's not able to be read.
Be sure the SD card is in the right slot and is in securely.
Make sure the card is not locked. It may be damaged and need to be reformatted.
Dec 05, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
My computer is not reading my kingston micro sd adapter
just insert any other sd card into the adapter and try it..... if it works fine then the problem is with your card.. if it doesnt work then the problem is with the adapter
Sep 27, 2008 | Motorola Mobility Boost i415 Cellular...
Sakar 50 In 1 Pocket Usb Hi Speed Card Reader & Writer - Cr-72 Logo
27 people viewed this question
Top Sakar Cameras Experts
Robert
Steven Wander
Steven Wander
Tony
Are you a Sakar Camera Expert? Answer questions, earn points and help others
