Question about Hasbro Furreal Friends Scamps My Playful Pup Electronic Dog Toy W/ Sound & Movement
Won't move
Has new batteries and I still can't get it to move.
Won t charge new battery
Few options: either the connection is "hazy" (try moving the plug in the hole), battery is fake or battery has been abused and is empty...
Aug 16, 2013 | HP Mini Computers & Internet
Computer
Could be it needs to be cleaned out. Or try different batteries. You might have put in ones that are old.
Jul 04, 2013 | Computers & Internet
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
2007 impala won't start sometimes
The most likely problem is a failed safety switch in the transmission. It will only allow the engine to turn over when in "neutral", or "Park". Next time it happens try moving the transmission selector through the full range of travel a couple of times. If this cures the problem, you may need new switch.
May 21, 2013 | 2007 Chevrolet Impala LS Sedan New Cars
Power comes on the bar bottom but won't come on the top and won't move and just stopped all itself while loading it
You need to allow the Battery to charge. If the Battery is not taking a charge, you need to replace the Battery
Apr 07, 2013 | Health & Beauty
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
Won't move when drive leaver pushed
go to my group page on facebook wac mobility scooter and i will message you.many thanks billy
Mar 19, 2013 | Pride Victory 4 Wheel Mid-Size Electric...
Dell precision m6300 battery won't charge.
You say it's a new battery. Is the battery the same EXACT spec? Some aftermarket batteries don't work well with your laptop. The pin-out/connections may be incompatible. That said, in your BIOS is there a "Battery Learning" section.
Jan 04, 2013 | Dell Precision M6300 Mobile Notebook
I have a problem with a 2008 Dodge Charger, my battery went bad and I had to jump it off to take it and get a new battery put in but now my new battery won't start my car not even when the new battery...
When you jump started the vehicle, it started as normal and you drove to a shop to have a new battery installed.?? Correct??
1. Who removed the old battery and installed the new one?
2. Did the car start normally immediately after the new battery was fitted? How frequently were you able to drive the car on the new battery before the problem you described appeared?
3. Has anything been done to the vehicle since the new battery was fitted.?
Dec 21, 2012 | Cars & Trucks
Perego Choo Choo will make noise, but won't move
the sounds are run off of a different battery source, check the battery under the seat and make sure that its connected
Apr 06, 2012 | Peg Perego Choo Choo Express Train Set
Hasbro Furreal Friends Scamps My Playful Pup Electronic Dog Toy W/ Sound & Movement Logo
89 people viewed this question
Top Hasbro Dogs Experts
Gary Clark
Gary Clark
Ruth summersides
Are you a Hasbro Dog Expert? Answer questions, earn points and help others
