What is the capacity of Kenmore 11022952100 - Washing Machines
Model 25371132104 KENMORE TOP-MOUNT REFRIGERATOR - we need the cubic for total capacity.
Kenmore refrigerators indicate the capacity with the third digit after the 3 digit prefix; thus the sixth digit is the critical one. Since that is a 1, I suspect the 253.71132104 has a capacity of 21 cubic feet. (If this is an apartment sized refrigerator, it could be be smaller - 11 cubic feet.)
I hope this helps.
Nov 06, 2016 | Kenmore Refrigerators
What is the capacity of Kenmore model
This may or may not help.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0305295.pdf
Nov 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
What is the capacity of my Kenmore washer?
3.2cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer leaks
Well Jeff to inspect where the leak is coming from you must remove the cabinet. Flip up the controls unplug the lid switch and pop the S-clips holding the cabinet to the back.Then you can tip the cabinet foward and lift it out the way. Click on this LINK for pictures.b3f4f26.jpg
May 16, 2009 | Washing Machines
Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
