Question about Packard Bell 160240 Mouse
The keyboard on my te69 easynote wont work. can you help?
Please help. i have a Packard Bell Easynote TJ74-RB-050 and the keyboard isn't working at all. im having to use the onscreen one which takes forever. i dont think the keyboard has got wet. it was...
It can happen for many things.
First if the keyboard become wet by water or other liquid then it happens.
2nd if the keyboard cable leakage from inside.
3rd if the keyboard circuit become fault or short circuit.
Solution under the here
1st, unplug your keyboard cable and then check your cable holder pin "if your keyboard is PS2 system" other wise no need. after unplug then plug your cable and restart your computer.
2nd, if your keyboard become wet then open it from back side and need to dry it just sunlight. after doing that please fitting your key board carefully.
3rd if your keyboard circuit become fault then you can wash it by thinner and then heat it by hot air gun.
other wise you need to a new keyboard. thanks
Apr 17, 2011 | Packard Bell Computers & Internet
How do I fit a new keyboard to an easynote C3 laptop
Are you asking how to connect an external keyboard?The easynote C3 has a parallel port on it. Hence you will have to get a keyboard(parallel port) and plug it into the slot. Thats all.
Regards,
Sai.
Nov 30, 2009 | Computers & Internet
PACKARD BELL EASYNOTE MV35-202 keyboard and mouse pad won't work
The first thing to do is my computer properties see if your keyboard and mouse are showing in there
If they are you need to update the drivers.
If they are not showing then I would suggest going to control panel and add new hardware installing that way
Try using a standard mouse instead of usb
If you cannot get on try restarting in safemode to correct your problem.
Or if you have a cd that came with the mouse and keyboard reinstall it.
Let me know if this helped also did you reinstall the same version of windows
Jan 10, 2009 | Computers & Internet
Packardbell easynote
First makes sure to dry the keyboard well somehow and try it after that. Turn the laptop upside down and try to let it dry.
If that does not work after it has dried well I think you need to replace your keyboard.
Meanwhile you can connect an external keyboard.
I hope that helps. I do not think you can do more.
Jan 16, 2008 | Packard Bell Easy One Silver 2101 Notebook
Non working keys on laptop
You should just need to replace the keyboard.
However finding a keyboard for a packard bell in the US can be hard. That brand hasnt been sold here in years.
If you are in europe it should be less of a problem though.
Made sure to get the exact model of the laptop to get the right keyboard.
Dec 20, 2007 | Packard Bell Easy One Silver 2101 Notebook
Packard Bell 160240 Mouse Logo
19 people viewed this question
Top Packard Bell Computers & Internet Experts
carey w mason
carey w mason
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
