Question about Panasonic KX-TGA101S Cordless Handset
NOTHING APPEARS ON TELEPHONE
Nothing appears on screen can't read anythingon screen
Change the display name?
Administering a 1400 Series Digital Deskphone
Perform the following steps for each 1400 Series Digital Deskphone:
1. Log into the Avaya Aura Communication Manager administration interface.
2. Perform one of the following steps:
? If you are adding a new extension and want to assign a specific extension number, use
the add station nnnn command, where nnnn is the new extension you want to assign.
? If you are adding a new extension and want to assign the next available extension
number, use the add station next command.
? If you are installing the 1400 Series Digital Deskphone at an existing extension, use the
change station nnnn command, where nnnn is the existing extension you want to
modify.
The Station screen appears.
3. Perform one of the following steps:
? If you are administering a 1408 telephone, type 2410 in the Type field.
? If you are administering a 1416 telephone, type 2420 in the Type field.
4. In the Port field, type the port address.
5. In the Name field, type the name to associate with this telephone. Administering 1400 Series Digital Deskphones
20 Avaya 1400 Series Digital Deskphones Installation and Maintenance Guide
6. Configure the remaining fields on the Station screen pages. Keep in mind the following
information:
? If you are administering a 1408 telephone, the first eight call appearance/feature buttons
displayed on the Station screen are administered on the 1408 telephone. (Since the 1408
telephone is aliased as a 2410 telephone, the Station screen displays 10 call
appearance/feature buttons.) The remaining buttons displayed on the Station screen are
not administered.
? If you are administering a 1416 telephone, the first 16 call appearance/feature buttons
displayed on the Station screen are administered on the 1416 telephone. (Since the 1416
telephone is aliased as a 2420 telephone, the Station screen displays 20 call
not administered.
? If you are administering a 1416 telephone with a DBM32 Button module, the first 16 call
appearance/feature buttons displayed on the Station screen are administered on the
1416 telephone. The remaining eight call appearance/feature buttons displayed on the
Station screen are administered on the first eight buttons of the DBM32 Button module.
The 24 buttons of the EU24 expansion module displayed on the Station screen are
administered for the remaining 24 buttons of the DBM32 Button module.
For more information about administration and features, see:
- Administering Avaya Aura™ Communication Manager, Document Number 03-300509
- Avaya Aura™ Communication Manager Feature Description and Implementation,
Document Number 555-245-205
- Avaya Aura™ Communication Manager Screen Reference, Document Number
03-602878
7. When finished administering this extension, save your changes.
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Dec 19, 2014 | Avaya Ip Office 1416 Digital Deskphone -...
The reading on my nokia 305 screen says CONTACT SERVICE and nothing else, what could be the problem?
When it says Contact Service then Contact Service. They will have a way to contact your phone to see what the problem is. Make sure you have the model number and serial number handy because they will want this. First contact tech service with your carrier then if you need to contact the manufactuerer service dept they will advise you and connect you to them.
Nov 25, 2014 | Nokia Asha 305 Silver White Unlocked...
Blue screen appears and message read I should installed bios
The BIOS must be installed or you would have nothing at all. Check drivers are installed.
Oct 07, 2014 | Computers & Internet
Panasonic KX-TG6421E UNWANTED VOICEMAIL ICON ON SCREEN, BYPASSING ANSWERPHONE
It appears your telephone service provider has turned on voice mail service. We recommend you turn off that service by contacting your service provider.
Mar 31, 2014 | Panasonic Lands Phones
Norstar M7324 DNS Update Code
Never heard of DNS.
Somebody made a programming change from that phone in the system and the system is updating all the phones.
When you press Update it show the ext's being updated, if it is that phone then unplug it for a few seconds should do the trick.
Nov 06, 2012 | NorStar M7324 Telephone
I have a singing machine, model STVG-1009, and the disk is not spinning and nothing reads on the screen. what could be the problem? how expensive is it to fix?
There appears to be a problem with the printed circuit board on these machines.
A possible fix is to remove the back cover then loosen the 4 screws holding the printed curcuit board.
Jan 28, 2012 | The Singing Machine Audio Players &...
Making noisewhen touching anythingon keyboard
Could use some more information, like make, model, operating system (XP, Vista, Windows 7) but try this:
Go into Control Panel-look for Sounds and Audio Devices; open the applet, disable the microphone or any type of audio boost.
Feb 03, 2010 | Office Equipment & Supplies
Caller ID
No. That phone is not caller ID compatible.
Nov 18, 2008 | Avaya AT&T Merlin BIS 34D Telephone
Canon Fax phone L80
If it is a dedicated fax line it is probabaly best set to fax only mode. Fewer rings (No more than two) FaxTel mode will ring for longer to allow you to pick it up if its a phone call.
Check if the machine has dial tone by onhook button or handset to check. If you have none try testing with another phone to rule out the machine.
Try a manual reception. Pick up the phone when it rings and press the start button.
Jan 31, 2008 | Canon FAXPHONE L80 Laser
Panasonic KX-TGA101S Cordless Handset Logo
26 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
