Question about Canon Elura 70 Mini DV Digital Camcorder
Tape does not eject - Canon Elura 70 Mini DV Digital Camcorder
Canon xl2 tape won't eject
This is a known problem.
Broken loading gear, Example: canon zr65 replace broken gear
Canon XL2 and ZR65 uses same tape drive system.
Feb 20, 2015 | Canon XL2 Mini DV Digital Camcorder
Why does my cassette player eject tape
Auto-eject mechanisms normally will eject the tape at the end of the tape. However, if the tape jams or is wound too tightly, it can cause the auto-eject to activate. This prevent tape breakage. Commercially recorded music tapes rarely get too tight, but the cheaper C90 and C120 tapes that people buy often will do this.
Aug 07, 2014 | Ac Delco Vehicle Parts & Accessories
Tape wont eject
From the tape library console, on the menu, select the slot view option, find out the slot of the tape you want to eject. Then move the tape in that slot to the male slot using the 'media move' option menu. The tape will be now ejected to the male slot.
Please come back and post your ratings if this solution helps you in anyway. Thnx
Mar 16, 2010 | HP StorageWorks DAT 72 Tape Drive
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
Tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Dec 19, 2008 | Emerson EWC1301 Combo
Eject a tape from my Sharp View Cam
Try removing the battery and reinstall it if you haven't all ready tried this
Sep 11, 2008 | Sharp Viewcam VL-A10U Camcorder
Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Feb 29, 2008 | Televison & Video
Cassette
Most VCR's will auto-rewind the tape when it gets to the end of a tape. Most will leave the tape in the unit assuming you may wish to view it again once rewound. Does the tape eject properly when you press the eject button? What does the manula say about the eject function?
- Jim
Jan 23, 2008 | Philips VR550 VHS VCR
My Drive will not eject the tape
Turn off the tape drive. (Switch in the back of the unit. Wait 2 minutes and then turn unit back on. Tape drive should issue a write data command and then rewind the tape. After rewind completes the tape should eject. If it does not eject after rrewind completes than try holding the eject button for 5 seconds to attempt a "force eject"
Note: Do not repeatedly press the eject button as this can cause damage to the tape and the tape drive.
Dec 07, 2007 | Quantum SDLT 320 External LVD...
Ultrium LTO 2 Tape Drive
Try holding the eject button down, for a long time, about 20 seconds (1 and 2 and ). This resets the tape drive, the lights on the front should go off, then come back on again. The tape will either eject automatically or will eject after the button is pressed normally.
The only time this dosen't work is if the tape is still out inside the drive.
Aug 14, 2007 | HP StorageWorks ESL712e Ultrium (AA934B)...
Canon Elura 70 Mini DV Digital Camcorder Logo
19 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
