Some station no signal other stations ok
Chanel 3 4 and 6 looks like areal problem all other Chanel's ok
thewrightbro
SOURCE: can not get tv stations above chanel 13
Switch To CAtV, You have setting on Antenna
Posted on Dec 01, 2008
tech48
  • 624 Answers
SOURCE: staion stuck on one picture and not responding but other stations
If all other stations are normal, then I believe that it is a problem with the station broadcast or the feed from your TV provider. I don't think you have anything to worry about on your end. It will most likely be all back to normal by the time you see this solution.
Posted on Feb 06, 2009
  • 280 Answers
SOURCE: Not getting signal for some of the channels in the area.
What is the source of your signal? ie cable, sat, or antenna?
If it is rabbit ears or antenna you may not have a strong enough signal.. With digital you have to have a preaty strong signal or it will come back with "weak signal or channel not found" You could try a signal booster.
Posted on May 01, 2009
milkburp
  • 416 Answers
SOURCE: I can see the cable guide and hear the chanel on
Cable boxes can latch up from time to time. It can be from a momentary poer loss or poor ventilation or any number of things. Try pulling the plug on your cable box for about 15 seconds, then plug it back in. Wait for it to reboot. If this does not correct the problem, contact your cable provider and ask them to send a reset signal to your box. I hope this was helpful, best wishes.
Posted on Mar 29, 2010
BElectric
  • 1140 Answers
SOURCE: all my chanels are blocked
You've probably activated the parental control / child lock. This can be done accidentally by pressing a certain combination of buttons on the remote. To turn this off:
1. Press the "MENU" button on the remote control
2. Select the "LOCK" option (the padlock icon) with the left and right arrow buttons "" ">" on the remote
3. Enter the password. The default is 0000 but yours appears to be set to 1111. Try either or both.
4. On the next screem make sure "SYSTEM LOCK" and "UNRATED LOCK" are set to "OFF". Highlight each option with the up and down arrows on the remote and change the setting using "" or ">"
5. When they are both set to "OFF", press "MENU" again to return to watching TV.
All your channels should now be unblocked.
Hope this helps. If you need further assistance, please post back.
Regards,
BElectric
Posted on Dec 05, 2010
Tip
Resetting the change oil,low tire,low oil ect. on 2004 impala
With the radio off. turn the key to the on position. press and hold the chanel knob in tell the info comes on in the station window. press the #1 to find the one you are looking for. press the station knob again( you will here a beep). Press #1 again and find exit and press the chanel knob again and it is reset.
on Mar 14, 2009 | 2004 Chevrolet Impala
Unable to retune comes back no channels found checked digital areal connection all ok.
where is your antenna located . possibly there are not stations close to your area ,and you need to be higher off the ground with it
Apr 17, 2016 | Televison & Video
Emerson tv 32 in --the channel 7.1 ABC only has picture without sound.
Check the Chanel 7 broadcast signal on the other tv have sound,could caused by the tv broadcasting signal from the tv station itself.Check if ur tv have a function known as S.A.P. make sure it is off,could effected no tv audio problems,because the tv station in ur city or town don't broadcast in that signal frequencies.
Feb 24, 2013 | Emerson Televison & Video
DAB preset is stuck on chanel 1. Machine will not allow DAB to retune or move to another chanel
Have you tried pressing the play mode button to change from preset to station list which will allow you to view all stations available.
Nathan.
Jan 14, 2011 | Panasonic SC-HC30 Audio Shelf System
Cant get any station other than chanel 3.It wont outo program and says there is no signal but channel 3 comes in.
Its likely the t/v has been programed to work with a cable
box , you can go to menu and settings and try to reset
it , or unplug it for a half hour or more and reset up the t/v
to scan channels.
Sep 02, 2010 | RCA F27665 27" TV
ONLY GETTING ONE STATION(3)
Try to search AUTO Program of chanel, and set your tv in CATV settings then run your program.
Apr 15, 2008 | Televison & Video
No sound from 1 station
Suggest a set-up procedue once again and see if that helps...accordianman
Jan 17, 2008 | Bose Lifestyle 38 System
Televison & Video Logo
10 people viewed this question
Top Televison & Video Experts
