Question about Traeger Industries Grilling
Traeger texas lid opens too far - Traeger Industries Grilling
When I start my Traeger grill it heats up and the temperature continues to climb and I'll not stop until I turn it off. Can you give me some information as to what I can do to fix this problem.
Ron, I am not real familiar with this model. If the temperature controls are not doing the trick, see if it has vent doors that can be slid open to help control heat. If it does not have vent doors, consider adding a couple to the top lid of grill. Link below how they work and install, you can also make your own quite simply.
BBQ Grill Burner Air Vent Installation and Adjustment Instructions
Apr 04, 2016 | Traeger Industries BBQ075 All-in-One Grill...
I keep getting an error msg. When it finally starts, it shuts off with the Err
Hi Terry,
This may help... ...from Treager's site FAQ
"My Unit Goes Out On Smoke
  1. Open the cooking chamber lid and remove cooking grill, angled drip pan and U-shaped firepot cover. Look and see if there is a large accumulation of pellet ash in and around the firepot. If there is, it will need to be cleaned out. Do this ONLY WHEN THE GRILL IS TOTALLY COLD! Replace U-shaped firepot cover, angled drip pan and cooking grills and resume cooking/smoking process.
  2. If this does not remedy the problem, please contact the Traeger Service Department."
From my personal experience, cleaning out the pellet ash is needed when the smoker will not hold a high temperature regardless of the thermostat setting.
In your case, the fire pot may be packed with pellet ash and pellets from the auger jamming.
Good luck.
May 29, 2015 | Traeger Industries BBQ070 All-in-One Grill...
How to remove the hot box
I don't believe the firepot is removable but you can access it for cleaning by removing the heavy metal pan under the grill and the cover over the firepot. It may be attached to the grill bottom with screws or rivets but the best way to clean it is with a shop vac. For specific information you might want to contact Traeger support at
Jun 24, 2014 | Traeger Industries Lil Texas Elite Grill,...
Traeger grill get to hot on smoke
If you're cooking when it's hot outside, it's hard to maintain low temperatures. In the heat of summer, I have to tend my grill continually opening and closing the lid to keep the temperature down to my cooking temp of 180. That, of course, lets the smoke escape. If it gets too hot when the temperatures are moderate, i.e. 60s and 70s, the augur may be dumping too many pellets into the fire pot and need realigning. I suggest you contact Traeger customer service at http://www.traegergrills.com and see what they suggest.
Apr 20, 2014 | Traeger Industries BBQ100 All-in-One Grill...
Not smoking
Traeger grills just will NOT smoke at temps much above 200 degrees. I have to stand by my grill continually in the summer to keep opening and closing the lid to let the heat out. That also lets the smoke out. I also have turned the grill off and on to try to maintain the temperature at 180 degrees where it smokes best and cooks low and slow. It's less of a problem in the winter months. Then I find myself setting the temperature higher turning it from low to medium and back to maintain the temperature I want.
Mar 30, 2014 | Traeger Industries BBQ070 All-in-One Grill...
Won't light
From Traeger:
Why won't my Grill Ignite?
  1. If your grill is plugged into an electrical outlet with a GFI (ground fault interrupter) plug, chances are the hot rod has absorbed or been exposed to too much moisture and is leaking to ground causing the plug to trip.
  2. Open your cooking chamber lid, remove cooking grill, angled drip pan and U-shaped firepot cover. Is there ash build up in the firepot and/or around the firepot? If so, this needs to be cleaned out. The ash is choking out the fire.
  3. Check the fuse on the back of the control board. To do this, first UNPLUG the grill from the electrical outlet. Then, unscrew the control board and look at the fuse-is it blown or not?
  4. If the fuse is good, check for power by switching the colored plugs first. Unplug the purple plug and the orange plug. Plug the purple plug into the orange plug. Now plug the power cord back into the electrical outlet and turn the grill on. Does the induction fan operate? If so, you will need a new hot rod and fuse. If not, you will need a new control board. Unplug the purple from the orange and reconnect the plugs together to their correct color plug.
  5. Always start your grill on the SMOKE setting.
Jan 22, 2014 | Traeger Industries Grilling
Need a treager lid handle
parts are available at the Traeger website at www.traegergrills.com. You need to contact them. It would be wise to have your model and serial number available.
Sep 09, 2013 | Traeger Industries Grilling
I turned off my grill yesterday and it kept on smoking. There seems to have been a fire at the base of the pellet bin. How can I fix this fast? I have three events beginning on Saturday, where my...
Whenever you finish using your Traeger it is always best to lift the lid and turn the controller down to the smoke setting and allow the temp to drop for a few minutes. This will also slow down the delivery of fresh pellets into your firepot thus starving the fire of fuel.Once the temp drops below 200 deg F than shut off the controller. If you have any wind blowing remove your Traeger out of the draft of the wind and the fire will go out on its own.
Jun 30, 2011 | Traeger Industries BBQ125 All-in-One Grill...
My traeger smoker will not ignite
From Traeger:
May 06, 2011 | Traeger Industries Grilling
Old BBQ100 that needs r4built
Here's the company contact info so you can get the parts directly.
To order parts directly from the factory:
PARTS DEPARTMENT
TRAEGER WOOD PELLET GRILLS LLC.
PO BOX 829 ,Mt. Angel, OR. 97362
(503) 845-9234 1-800-872-3437
Fax: (503) 845-6366
Email: traeger@traegergrills.com
Website: www.traegergrills.com
May 15, 2010 | Traeger Industries BBQ100 All-in-One Grill...
Grilling Logo
Top Traeger Industries Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
