Question about Millennium Enterprises SRC-8000 Universal Learning Remote Remote Control
Millennium CRK 1008 - Millennium Enterprises SRC-8000 Universal Learning Remote Remote Control
L want advice on the best bernina to buy, 1008 or 1010. what is the difference between 1008 and 1008S and 1008ES
The machines are the same, the only difference in the 1010 was made from 1989 to 1991, the 1008 in the new version! Both great machines!
Aug 19, 2010 | Bernina 1008
Engine is running like a plug wire is off -codes say map sensor, crk sensor, vacuum leak - did not shift into high quite right for two weeks leading up to this - plugs, wires ok - where is map sensor and...
these sensors are in you vacume lines. You can tell which ones because they are thin black hoses with mulitple extensions on them. You are looking for components with electrical wiring running form the hoses to the vehicles "brain".
Feb 03, 2010 | 2006 Isuzu i-280
System carnt read sdcard in reader via usb port i run windows millennium
Windows Millennium is no longer supported by Microsoft. You should seriously consider updating to a new O/S considering Millennium is over 10 yrs old.
Jan 09, 2010 | Compaq Presario 5000 PC Desktop
How to set my Bernina 1008 sewing machine up for sewing
That information is in the instruction manual that's available here:
Bernina 1008 Sewing Machine Instruction Manual
Dec 01, 2009 | Bernina 1008
I CAN'T FIND THE RIGHT BULB FOR MY 1008 BERNINA.EITHER the BASE IS TOO LARGE OR TOO SMALL
It's a special bulb. Try a Bernina Dealer. I saw one the other day around $12
Mar 16, 2009 | Bernina 1008
Xbox
The drive motor is SERIOUSLY damaged. It will have to be replaced, but good luck finding parts. Call around to local service shops and see if any have parts units.
Sep 20, 2007 | Microsoft Xbox 360 Console
360 grinding noise and unplayable disc
Crack open the DVD case and see whats going on and try fixing it yourself. OR Buy a new drive off of eBay and transfer the firmware key over from the old drive too the new one.
Televison & Video Logo
26 people viewed this question
Top Millennium Enterprises Televison & Video Experts
Are you a Millennium Enterprises Televison and Video Expert? Answer questions, earn points and help others
