Question about Manitowoc Ice SM-50A Undercounter Ice Maker 53 lb/day & 25 lb Bin
Manitowoc troubleshooting It isn't making as much ice as it had been. Initially in the morning the bin would be extremely full. Now it only produces about 15 lbs and takes 26 min between each cycle. What do I need to do to get the production back up?
  • 884 Answers
Clean the condenser thoroughly, descale and sanitise the waterways inside.
Posted on Apr 05, 2014
Mantiwoc ice machine
try to run a full clean cycle with nickel safe cleaner.
Nov 26, 2014 | Refrigerators
My Icemaker won't keep the ice once it makes it
What make and model of ice maker do you have?
Is the unit making ice? If so, about how much?
Most commercial bin type ice makers are not engineered to maintain the ice once it drops into the bin. Older ice is intended to melt and the water should drain out of the bin as new ice is deposited on top.
It may be that you are consuming ice at a rate greater than the unit is designed to produce ice, or that the unit is not set to the highest ice production rate (if adjustable).
Alternatively, if the inside of the bin is hot (warm) you may have another problem with the unit (e.g., gasket leak). Was the unit previously working? If so, are you aware of any events that took place just prior to the change?
Some units have a defrost or a cleaning mode, which will actually generate heat inside the unit. Make sure the unit is set to the correct mode.
Feb 12, 2014 | Manitowoc QM30 Under Counter Ice Maker
I just emptied all the ice out of my ice bin to take on a picnic, but now my ice maker won't make more ice. I have had it for 5 years with no problems. What happened? Did some setting get bumped? or...
1. Check to make sure the when you removed the ice bin that you did not leave the lever by the ice tray in the up position. That is the one the stops the making of ice whe the bin is full. This is the only easy solution.
2. Check to make sure that the vent between the freezer side and produce bin is closed. This is used when opened to keep that bin colder than the rest of the fridge. If that isn't it then there a few easy solutions.
Jul 02, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I have a Manitowoc QD0212A 120v. It makes ice, but after the bin gets full, it appears that the compressor does not run to cool the ice box. Is there some type of relay or solenoid that could be bad?
Try cleaning the radiator for the ice box compressor it could be tripping it's thermal overload switch, if that doesn't work check to see if the termostat setting is in the range for the compressor to turn on when the ice starts melting.
Jun 29, 2011 | Manitowoc - QD-0212A/115-1
Manitowoc Ice machine only makes 2/3 bin of Ice and shuts off
The unit shuts off based on the magnetic reed switch in the plastic curtain on the front of the evaporator. If the ice is not falling as one single sheet with about 1/4"-3/8" of a bridge conecting all of the cubes then the ice is too thin. When the ice falls (in a single sheet of ice) if there is enough ice in the bin to hold that ice up and keep the curtain open the unit shuts down. A full bin may only be what appears to be 2/3 or 3/4 of a bin full because the ice sheet is propped up behind the curtain. If the ice sheet is too thin and does not fall as a single sheet more often than not a single cube or a piece of a cube can get caught between the curtain and the evaporator plate. This can shut the unit down for several hours until that piece melts and the curtain closes again.
Dec 19, 2010 | Manitowoc - QD-0212A/115-1
I have a model qd0452a manitowoc and it will not stop making ice
Very unusual for one of these to not stop. There is a magnetic proximity switch located on the bottom right side of the water curtain that serves to both cancel a harvest/drop and to shut the unit down on a full bin. When a drop occurs the control board sees a open and then close of the switch and restarts a freeze mode. If the ice drops and the bin is full the curtain is blocked by the ice behind it from closing again and the unit shuts down on a full bin indication. If the curtain does not open and close after 3 hours it would lock the unit out. Therefore I assume that the switch and the board are working. Most likely you either have the unit on a non-Manitowoc bin or are missing a deflector plate in the Manitowoc bin and the ice is falling out of a service door.
Nov 17, 2010 | Manitowoc SY0454A S Series Ice Maker...
Manitowoc ice machine that will not produce ice
This is odd that Manitowoc is listed on a page showing a Whirlpool refrigerator model and number. What is the model number listed on your Manitowoc? Not the base model number. The number listed inside the top section. Manitowoc has a really good service reputation. Their control boards have a series of self diagnostics. Get me your model and we will go from there. Sea Breeze
Jun 11, 2009 | Whirlpool ES5FHAXS Side by Side...
Ice Maker Not Producing Ice
Have you reset the power? Is the bin fully inserted in the cavity? Are there any shutoff or bin full indicators that are not in the run position?
Dec 09, 2007 | Sub-Zero 632 / S
Manitowoc Ice SM-50A Undercounter Ice Maker 53 lb/day & 25 lb Bin Logo
151 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
John Tripp
John Tripp
mike cooper
Dan Webster
Dan Webster
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
