Question about Moen Home
Homelite 3500 voltamatic exploded parts
Moen 3500 valve would not turn to the other positions. Took it apart and can not figure out how the cartridge can change position when the two pins lock into the valve body
  • 33 Answers
SOURCE: replaced moen 2225 cartridge leaks when valve is turned on
Make sure that you did not pinch an O ring seal when you were installing the cartridge. If so replace O ring. when installing new cartridge try putting a little Vaseline on all the O rings. It will seal better. It is rare but you could have purchased a defective cartridge. Never buy a cartridge if the package was opened because maybe someone just needed the O ring that is making your faucet leak :-)
Posted on Jan 26, 2009
Bati99
  • 88 Answers
SOURCE: Shower valve leaking
here is the link to the pdf file http://www.plumbersurplus.com/pdf/07606.pdf
If you cant get directly to it from the above link, go to plumbersurplus.com/prod/danze-D51001BNT then click on "documents"
Posted on Apr 17, 2009
  • 49 Answers
SOURCE: moen tub and shower will only allow cold water
sounds to me like someone turned off your hot water at the valve.
Posted on Sep 03, 2009
heatman101
  • 43501 Answers
SOURCE: replace the cartridge for a moen shower
It is stuck, they come out very hard and a puller is made to make removal easier.
Posted on Nov 12, 2009
  • 25 Answers
SOURCE: took apart Moen tub faucet to replace cartridge
hi, there is a lock nut that holds the cartridge in this will need to be unscrewed, if you have already done that it should only be a matter of pulling it straight out, sometimes the cartridge gets seized in the body of the tap use mutli grips or pliers to pull it out by the shaft that the handle goes on
Posted on Jul 14, 2010
I can't get to the cartridge inside my Moen Aberdeen handle
The detailed exploded view of the parts is in this sheet.
Hope this is the right model that you have.
http://www.moen.com/shared/docs/exploded-parts-views/7590cpt.pdf
you will need to undo the nut holding the cartrigde in place. Sometimes you will have to get a special tool to undo these parts.
Apr 19, 2014 | Plumbing
My cartridge is clogged
Here are two links to the exploded parts diagram and the installation instruction:
http://www.moen.com/shared/docs/exploded-parts-views/87499pt.pdf
http://www.moen.com/shared/docs/instruction-sheets/ins10205.pdf
You may refer to them to take the cartridge out.
Feb 11, 2014 | Moen 87499SRS Harlon High Arc Kitchen...
Moen banbury faucet repair
I had a look at the installation guide and exploded diagram, It seems that the whole assembly will be tightened when the mounting nut is put on.
The links to the installation guide and exploded diagram are:
http://www.moen.com/shared/docs/instruction-sheets/ins2224.pdf
http://www.moen.com/shared/docs/exploded-parts-views/87017pt.pdf
Jan 18, 2014 | Plumbing
How to remove catridge from T934BN vestige
The link to the parts diagram is provided here for your reference.
From the diagram, find out the parts to be losen for accessing the cartridge.
http://www.moen.com/shared/docs/exploded-parts-views/t934pt.pdf
Dec 08, 2013 | Moen T934BN Vestige Two Handle Roman Tub...
I need a piping diagram for a Moen s3371 and a s3600 valve
http://www.moen.com/shared/docs/product-specifications/s3600sp.pdf
http://www.moen.com/shared/docs/instruction-sheets/ins1281c.pdf
http://www.moen.com/shared/docs/exploded-parts-views/s3600pt.pdf
http://www.moen.com/shared/docs/exploded-parts-views/s3371pt.pdf
If you did your rough in for the hot water coming up from the left of the valve as you face the control and the cold on the right, that is traditionally correct.
Jan 15, 2012 | Moen Plumbing
Water leaking from handle area (stops when you turn the shower on). How do I get the handle off to get to the cartridge?
Moen model L2175 has a set screw located under the handle or bottom side of handle that you must remove to gain access to cartridge....... Be sure water is turned off and you release water pressure before removing cartridge....... After removing handle there are a few more parts that will need to be removed(scald guard app.) may want to take notice which order you remove these so you want get parts mixed-u p. May-be this link will help you , it is an exploded view of parts and how they are can be removed
http://moenparts.faucetdirect.com/mediabase/specifications/ins162e.pdfp
Sep 05, 2011 | Moen L3175 Legend One Handle Shower Faucet...
Hot water handle got loose then eventually popped off this model Moen L4720 Villeta faucet. Where can I go for detailed repair instructions?
http://www.moen.com/shared/docs/exploded-parts-views/l4720pt.pdf
i just sent you a clarification request. The link above is an exploded parts diagram. You should be able to get some of these parts at lowes or home depot. Especially the cartridge.
No really all you have to do to change them out is turn off the water supply, and use the diagram to tell which parts go on when. I doubt you will be able to get everything from the store. But you can probably get any part on there from the moen website.
I hope this helps. I will be more than happy to help you further if you need it.
Thanks,
Mike
Jul 27, 2011 | Moen Villeta Chrome Faucet W/ Valve &...
I have a moen single handle tub and shower faucet took out the clip and pulled but the stem will not come out what esle is holding it
You need to purchase a replacement cartridge before trying to remove a defective Moen cartridge. Always buy genuine Moen. If your valve turns on and off with a pull/push action you need part number 1225B, otherwise you need part number 1222. The 1200 cartridge will work in lieu of the 1225B but is more expensive and no longer used in Moen valves. There is a tool that comes with these cartridges which looks a bit like a white plastic cap.with notches on one end and a square head on the other.
Once the clip has been removed the only thing keeping the cartridge in the vslve is old sticky lubricant. Place the tool over the cartridge end and rotate as necessary until the notches are fully engaged and it no longer rotates. Using pliers or a wrench over the squared end, twist the tool back and forth several times. Remove the tool, and using pliers, pull the old cartridge out. Put the tool on the replacement part and insert it back into the valve. Lightly tap on the squared end to make sure the new part is completely seated, then use the squared end again to turn the cartridge as necessary to align for the clip to be reinstalled.
Nov 06, 2010 | Moen & One Handle Tub & Shower Faucet
I was able to figure out how to get the handles apart, but can't figure out for the life of me how to get the center spout removed. Faucet is a Moen & Villeta Two Handle Lavatory Faucet
I took a look at the brand on the web and though I do not know your model, it appears that the center spout would have to be loosened from down under the sink and then pulled up from the top. Those units usually come in three parts, two valves and the spout. The valves are put in from under the vanity/sink and the spout is put in from above the vanity/sink.
Sep 15, 2010 | Moen & Villeta Two Handle Lavatory Faucet
No cold water from Moen 2253 tub/shower valve, when i turn handle to cold I get hot water, when handle is turn to hot i get hot water
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Apr 05, 2010 | Moen & One Handle Tub & Shower Faucet
Home Logo
117 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
