Question about AUVIO Stereo Wireless Headphones
Pairing how do I pair my wireless plantronics to my avuio receiver? They are both blinking but I don't know how to put a pair code of 0000 in it to pair. HELP
I want to pair my new cell phone with my headset 3xx plantronics but I need a passkey I don't have the instruction What can I do ?
Once you make your phone discoverable, then put the headset into pairing mode by pressing the call control button until it flashes red and blue. The passkey is " 0000 " (four zeros). Here is a link for the pairing instructions:
Plantronics Explorer Pairing Instructions
Good luck from Headsets Direct!
Oct 16, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How do I put the unit in discover mode
Putting the Plantronics Voyager 510 into pairing mode:
With headset on, press and hold the call button and the volume up simultaneously until the headset begins to flash red and blue.
Select the Plantronics 510 headset in your phone when prompted and enter 0000 (4 zeros) as the PIN/passcode if prompted. When paired, the Voyager 510 headset should now have a continuous blinking blue light. Here is a link below for the step by step pairing instructions.
http://www.headsetsdirect.com/plantronics-voyager-510-bluetooth-pairing-instructions
Good luck from Headsets Direct - 800-914-7996.
Aug 12, 2011 | Plantronics 510 Voyager Headset - PLN-510...
I go to set up my wireless headset with my playstation 3 but it won't pick up any devices.
You must put both the PS3 and the Backbeat into pairing mode. See your instruction manual for the PS3 for pairing. Once you have both devices searching for each other they should pair right up.
Instructions for putting the Backbeat 903 in pairing mode:
With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
Use the PS3's menu to search for the Bluetooth headphones and select 9xxBackBeat.
If prompted, enter 0000 for the PIN code/passkey.
Here is a link for the User's Guide:
Plantronics Backbeat User's Guide
Mar 23, 2011 | Plantronics Backbeat 903 Bluetooth...
Please help pair my Explore 233 to a Samsung T-mobile
The default pairing code for Plantronics is 0000 (4 zeros). If you need more help, try their interactive pairing guide: http://www.plantronics.com/media/media_resources/easytopair/
Sep 01, 2010 | Plantronics Explorer 220 Bluetooth Headset...
My plantronics explorer 230 wont work
i had a similar problem. i think you need to know how to put your headset into pairing mode. thats all. puting your device on with the blue light flashing is different from puting it on pairing mode. i have a plantronics 330. and to put it on pairing mode i had to start with the divice off. then press the button and hold it untill the blue light flashes. then keep holding it until the blue and the red light flashes one after the other. then leave it. at that point the headset is on pairing mode. from there you can find it on your phone. but you're going to need a pass code though.most devices work with 0000 (4 zeros) or 1111 (4 ones). i didnt know mine and it worked with 0000. good luck!
Sep 07, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Headset not going into pairing mode.
Hold down round button on earbud for 5-6 seconds until the lights blink alternating red and blue.....then, enable your phone/device to connect in pairing mode. This will be a "find device" command or something similar. Once they recognize each other....it will send you a screen to enter a code. This will be 0000.....enter that...and once they pair...you are good to go.
Aug 07, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Pairing code
0000 it is default pairing code try it..
Feb 24, 2009 | Plantronics Explorer 320 Wireless Headset
AUVIO Stereo Wireless Headphones Logo
104 people viewed this question
Top AUVIO Audio Players & Recorders Experts
 Mikey
Mikey
L Pfaff
L Pfaff
Vladimir Frolov
Are you an AUVIO Audio Player and Recorder Expert? Answer questions, earn points and help others
